jabb's Avatar
Post Rev Limiter for 3.0
I have a 3.0 that has Webers and a Euro
distributor. On the 3.0 with CIS i blieve the rev limiter is a fuel cut off. Anyone know of a Revlimiting rotor that can be used
on the 3.0 with a Euro distributor.
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 07-07-2001, 11:43 AM
Senior Member
Post
Hello
Sure but the 3,0 had two distributor cap types so you need the mathing finger to your cap.
Grüsse
Old 07-08-2001, 07:53 AM
jabb's Avatar
Post
Not sure what you mean... Sorry
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 07-08-2001, 10:38 AM
RETIRED
Joe Bob's Avatar
Post
The 3.0 has a rotor, that has a spring mounted in it....when it gets to the rpms that is inscribed on the side, it is supposed to cut spark.
I use them and it does it's job.
Old 07-08-2001, 01:55 PM
Senior Member
Post
Hello
on the 3.0 with a Euro distributor. <
You said it yourself ! Rhetoric Question ?
And to go sure the 3,0 has two different cap/finger combinations so make sure you order the correct finger to your cap.
Grüsse
Old 07-08-2001, 08:42 PM
Senior Member
Zendalar's Avatar
Post
I removed my rev-limiter from the distributor "roller" because it was cutting off the spark (?) whenever it feeled like. Now I have a match broken in half inside the "roller" so the rev-limiter won't engage, ever.
Ok, it might be little hazardous, but I am not going to rev it up so much...
Old 07-09-2001, 01:19 AM
jabb's Avatar
Post
I am looking for a part ## sorry about the confusion....
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 07-09-2001, 08:41 AM
RETIRED
Joe Bob's Avatar
Post
I would have to look at home for the #....but both Pelican and/or the dealer can provide that.
BTW....You need to specify the rpm that you want it to cut out at though....my street one cuts out at 6800 rpms, I have a variety of spares that go up to 7300.
Old 07-09-2001, 03:05 PM
