Scraping Noise from Steering Wheel
I replaced my stock wheel with a 930S wheel from AJ USA.
There is a scraping noise when I turn the wheel. I applied dielectric grease to the horn contact and wiper. The noise goes away, but returns a month or less afterwards. It's definitely the steering column, and definitely in the wheel. Anyone have any ideas of what else might be causing this noise and/or eliminating it? Any thoughts appreciated! Don |
I would honestly try replacing the column bushing. It's a simple pound-it-in replacement that cures most steering wheel ills with rough movement and the like. But if the dielectric grease *really* makes the grinding feel go away....
...try shaping the horn ring contact (the part on the car side, not the wheel contact) to be a little flatter. I did this and it fixed the problem for me. |
If you do replace that bushing, don't replace it with another of the lousy plastic ones. There's a metal 928 bushing that is the preferred fix.
Stephan |
I had this problem when I fitted a new wheel. It was the horn contact. I did what old_skul suggested.
Thanks for the suggestions guys - I'll try them this weekend.
Don |
| All times are GMT -8. The time now is 06:30 PM. |
