Don Plumley's Avatar
Question Scraping Noise from Steering Wheel
I replaced my stock wheel with a 930S wheel from AJ USA.
There is a scraping noise when I turn the wheel. I applied dielectric grease to the horn contact and wiper. The noise goes away, but returns a month or less afterwards. It's definitely the steering column, and definitely in the wheel.
Anyone have any ideas of what else might be causing this noise and/or eliminating it?
Any thoughts appreciated!
Don
Don Plumley
M235i
Old 01-31-2002, 09:29 PM
Send a message via ICQ to old_skul
I would honestly try replacing the column bushing. It's a simple pound-it-in replacement that cures most steering wheel ills with rough movement and the like. But if the dielectric grease *really* makes the grinding feel go away....
...try shaping the horn ring contact (the part on the car side, not the wheel contact) to be a little flatter. I did this and it fixed the problem for me.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 01-31-2002, 10:03 PM
If you do replace that bushing, don't replace it with another of the lousy plastic ones. There's a metal 928 bushing that is the preferred fix.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 02-01-2002, 04:59 AM
Glasgow 911SC's Avatar
I had this problem when I fitted a new wheel. It was the horn contact. I did what old_skul suggested.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 02-01-2002, 06:57 AM
Thumbs up
Thanks for the suggestions guys - I'll try them this weekend.
Don
Old 02-01-2002, 09:58 AM
