1980 911 SC Interior Door Handle Replacement
Can someone explain how to replace the interior door handle replacement procedure? Hopefully this can be accomplished without removing the panel...thanks in advance.
Old 09-16-2010, 06:44 AM
With the handle in the open position, pop the end of the rod that runs back inside the door where it meets the handle. The rod has an L shape on the end that fits a hole in the handle. The handle pivots on a metal rod held in by two very small C clips (top and bottom). Remove each C clip and the rod will slide out and the handle is removed. Installation is the reverse. I removed the C clips with the whole armrest out of the car. Did I mention the C clips are very small?
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 09-16-2010, 10:55 AM
Install is complete.
Thank you.
1986 944 Racecar
2000 Boxster ClubSport
Old 09-17-2010, 11:03 AM
nineball's Avatar
actually you only need to remove the top c-clip and the pivot rod will fall out the bottom. trust me, the fewer clips you remove the easier the job will be. have a magnet on hand when doing this as you have a better than 50/50 chance of dropping one of those little buggers.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 09-17-2010, 02:27 PM
Send a message via AIM to MrNvgtr
Bump because I'm in the middle of this right now and can't get that paper thin tiny C-clip to slide out. What's the trick? Special tool? All I have handy is some needle nose plyers and a small Swiss army knife. The C-clip has such a low profile that I can't get a hold of it.
Except for the broken plastic interior door latch that I'm replacing, no other part of the door has been removed, yet. Any suggestions would be appreciated. Thanks.
Michael
'91 Porsche 964
Old 02-20-2011, 05:34 PM
I took the whole handle off the door then used the end of a small screw driver.
Old 02-20-2011, 07:44 PM
@Kiwiokie - Thanks a bunch. That got me headed in the right direction.
Those microscopic c-clips were a pain in the butt. A combination of will power and my micro-sized screw driver set got me through it. Then it was all downhill from there. Feels so good to be able to exit my car without rolling down the window to unlatch from the outside.
Michael
'91 Porsche 964
Old 02-20-2011, 10:32 PM
Recreational Mechanic
Nickshu's Avatar
Someone out there sells a metal replacement for the OEM plastic handle (maybe Pelican or Automotion?). A good chance to upgrade. Mine bends every time I pull the door...waiting for it to snap off so I have an excuse to buy a metal one!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 02-21-2011, 05:20 AM
