michaelw's Avatar
Bad idle/running rich 3.2!
Still trying to fix the rich condition on my 87 3.2. Replaced the 02 sensor and the DME. Car runs better, but idle, after taking rpm's up to 2500, falls down to 400-500, then slowly works its way back up to about 1000rpms and still have some black smoke. Idle also bounces a little on startup.
Tried to adjust the idle down (by shorting the circuit and turning the screw) but it won't budge no matter how much I turn the screw. What gives? Where should I check next? The idle stabilizer valve, the head temp sensor or airflow meter? Would the CO mixture affect idle and running performance?
Thanks guys, I am hunting the archives as we speak, but imagine somebody can save me some time.
Michael
Old 02-01-2002, 02:33 PM
Running rich (engine that is)
I know the feeling. There is lot's of information on this site for the condition.
I recently cured the problem (with the help of many here who responded to my similar condition, thank you very much) by replacing the temp head sensor, and then had the mass flow potentimeter resistance reset as per the supplier. Found out is way out of whack so it could have simply been it to start.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 02-01-2002, 03:18 PM
Is your ISV pulsing?
I would think it is either a problem with your barn door CO setting, or maybe a RPM sensor is bad.
Could also be leaky injectors...
Good Luck
Nick
'85 Carrera
Old 02-01-2002, 03:35 PM
michaelw's Avatar
Re: Running rich (engine that is)
How did you/they reset the the mass flow potentimeter?
Thanks,
Michael
Old 02-02-2002, 04:58 AM
