-   -   911 sc starting issue (http://forums.pelicanparts.com/porsche-911-technical-forum/587238-911-sc-starting-issue.html)
Bob Kontak 10-22-2011 06:22 PM
Yes, it is do-able even by a "BT" guy like I was (BT = Before Tony) You won't get absolute perfection but you can get real close.
It is a moderate PITA to get the allen screw down in there. Let me get some better pics and I will pull some posts together for you so you can absorb them. There also is a slim chance you may have an anti tampering plug (or dust plug) in there but I bet they did not put them on ROW cars.
Hold this space..........
boyt911sc 10-22-2011 06:40 PM
Too old but could still quicker than most guys......
Bob,
Why are you picking on an old senior citizen like me? Remember you'll be like me someday. BTW, I have some pictures to share.
http://forums.pelicanparts.com/uploa...1319333976.jpg
http://forums.pelicanparts.com/uploa...1319333989.jpg
Tony
Bob Kontak 10-22-2011 07:45 PM
Thank you for the pics. Perfect.
That is a sweet 3mm wrench. You will notice Tony has his last will and testament packed into that handle bore. http://forums.pelicanparts.com/support/smileys/wat3.gif
I just bought these at Harbor Freight Tools and they were $7 on sale. They do not clear the metal fuel lines on my 81 but they will work on the non-metal ones.
http://forums.pelicanparts.com/uploa...1319337833.jpg
scott.k 10-22-2011 09:13 PM
Bob, I think im going to buy those. harbor freight is now selling them for 4 dollars on sale. out of curiosity, will the 3mm wrench fit down under the top of the back seat/ top of the engine compartment, if not ill have to make one of those two piece ones depicted earlier.
Bob Kontak 10-22-2011 09:28 PM
Do you have the "plastic" lines? If so, yes they will fit.
boyt911sc 10-23-2011 06:12 AM
Too long........
Those colored T-handle allen wrenches are too long to fit with the engine installed in the car. Even if you don't have any sound pad, there is not enough room to wiggle it into the hole. The HF allen wrenches (shown in previous posts) are more than 6" long. I could use the HF wrench with the engine off the car. I'm using a 4.5" long allen wrench and it's a tight fit.
Try to put a 6" long wire and see if that would get into the hole. I could not get anywhere close with the 6" allen wrench. Let us know. Thanks.
Tony
Bob Kontak 10-23-2011 12:51 PM
Six inch would never make it. These HF ones are spec over 5 1/2". I do not have a sound pad and it is tight tight tight and maybe impossible for a hole that has not been mangled like mine. I am taking some measurements and some pics with my regular tool I use vs the HFT wrench.
Some of the tip of the HF tool could be cut off and it would be ok clearance wise.- heck, even the handle ends could be lopped off for side clearance problems with the metal fuel lines.
Did you make that tool, Tony? That is slick.
Bob Kontak 10-23-2011 02:11 PM
3mm wrench length
HF wrench is just a spec over 5.5" It barely fits in my car because I have no sound pad and two holes drilled (factory and "other") The boss the factory hole is drilled into, when they drilled the other hole, has been chewed up enough to allow clearance. Will not be even close to clearing with a sound pad.
Here is wrench along side the wrench set I normally use. My DIY made 3mm bit is 3 3/4 inches long. It should be 4 inches to allow the big allen wrench I use to clear the metal lines better. Works but rubs.
Some of this is moot is you have plastic lines. The 4 1/2 inch length Tony uses can be achieved by cutting one inch off the 5 1/2" HF wrench. IF you have metal lines you will have to cut down the wings of the handle to skinny it up. Tony - Yes, that is rust on the handle of my 12" precision square.
http://forums.pelicanparts.com/uploa...1319404076.jpg
FWIW - Here is my set of adjustment holes.
http://forums.pelicanparts.com/uploa...1319404239.jpg
boyt911sc 10-23-2011 02:45 PM
That's another HF set.........
Bob,
The 3-m allen wrench in the picture is part of a set from HF and slightly over 6". I got a 4.5" length allen wrench similar to yours. There are several special tools and gadgets that I made from scratch and use them on regular basis.
Tony
Bob Kontak 10-23-2011 03:19 PM
HFT - You are correct, Sir! Except the one in my set is 5.5"" and is un-cut. They must have different length sets.
edit - The 10mm in my set is 6 1/16th.
scott.k 10-23-2011 04:57 PM
yes, i do. believe it or not, im so impatient i couldnt wait so i just ran to osh, bought a $4 set of metric wrenches and they fit without modification. i was really happy and surprised with that. i can only do small turns but it gets the job done. just to verify, clockwise = richer?
thanks
scott
Bob Kontak 10-23-2011 05:18 PM
Correct.
Good luck. Make sure the car is completely warm. I am talking at least 20 minutes at idle (I don't think you are roadworthy, right?) and make sure the Aux Air valve and WUR electric connections are intact.
Edit - No dwell meter still, correct? A dwell meter is $30 and exhaust analyzer is hundreds on up. Dwell meter is second string behind an analyzer but is pretty effective. I will find you Soukus' thread on doing it w/o an analyzer and post asap.
Edit - Here is is.
http://forums.pelicanparts.com/porsche-911-technical-forum/232089-cis-idle-speed-mixture-setting-without-analyzer.html
scott.k 10-23-2011 06:02 PM
Originally Posted by Bob Kontak (Post 6327343)
Correct.
Edit - Here is is.
only 30 bucks? alright, im going to get one to fine tune the air fuel mixture right. all the connections are in tact and i will let it warm up and then do some adjusting.
thanks
scott
Bob Kontak 10-23-2011 06:20 PM
Originally Posted by scott.k (Post 6327428)
only 30 bucks?
I lied. $38. I bought mine back in 1927, the day Tony had his 20th high school reunion.
The mighty Actron:
Buy Actron Dwell/Tach/Volt Analyzer CP7605 at Advance Auto Parts
scott.k 10-23-2011 08:57 PM
The mighty Actron:
haha
looks great to me.
thanks
T77911S 10-24-2011 05:22 AM
the 3mm allen out of the sears set fits perfectly.
scott.k 10-24-2011 08:57 PM
Correct.
Edit - Here is is.
wow, thanks for the link. way more in depth than I would have expected. I have been doing it by hand/ with no testers thus far and I think I will continue that way with the help of this thread.
Scott
Bob Kontak 10-24-2011 11:06 PM
Hope it helps.
NOLAsc 10-25-2011 03:58 AM
Originally Posted by scott.k (Post 6220506)
Bob, thanks. So form what I understand, I repeat the test I did thursday, but this time, i walk back to the engine and hold the fv, which should be buzzing/vibrating?
Scott, how did this test work out for you?
I'm having cold start issues on my '82, and I wonder if it is lack of power to my lambda sys (and FV?). I have a short somewhere that keeps blowing fuse 18.
Good luck.
NOLAsc 10-26-2011 09:16 AM
Good luck.
For what it's worth, lately, my '82 had been coughing and spitting at start-up until the engine warmed. Actually the only way to start the car was to richen the mixture using the 3-mm allen wrench.
I got power back to the O2 system under the seat and the car started right up this morning. See: http://forums.pelicanparts.com/porsche-911-technical-forum/550846-fuse-18-blowing.html
Now I need to fix the mix again. Don't mean to hijack, but I'm gonna ask another question or two about the dwell meter thing on your thread shortly.
