Here's the dwell meter I have on hand. (I must have bought it for my dad in the '80s.) It looks like it needs to be connected to positive as well as ground. The directions only show the green wire going to the coil (if I recall). Do you think this will work? http://forums.pelicanparts.com/uploa...1319646060.jpg Thanks, Shawn |
If the O2 relay isn't working, you will have more than just cold start issues. The car will barely run and will sure as hell be backfiring.
I don't see a cylinder 4 - 6 - 8 selector but you have three scales. Use the 4 cyl scale unless there is a switch and then switch that to 4. |
| All times are GMT -8. The time now is 02:47 AM. |
