-   -   911 sc starting issue (http://forums.pelicanparts.com/porsche-911-technical-forum/587238-911-sc-starting-issue.html)
tirwin 08-25-2011 09:54 PM
Scott,
I just saw this thread. I can post a pic in the morning but you need to look at pg. 240-11 in the Bentley manua if you have itl. You need a fused jumper and a switch. I did this recently myself. I went to my local auto parts store and bought a 50 amp switch, a mini-fuse holder w/ 25 amp fuse, 14 gauge wire and some bullet connectors. You want to use that to connect just relay pin 30 to 87a. Remove the fuel pump relay of course. Turn the ignition to on position (not all the way to cranking). Then you can flip the switch to turn the fuel pump on and off.
Bob Kontak 08-25-2011 09:59 PM
I have the charts - will scan and post in a minute.
boyt911sc 08-25-2011 10:03 PM
You're in good hands.........
Originally Posted by scott.k (Post 6218648)
Haha, tony, yes your first sentence is most definitely correct. I realized that much when the motor tried to start. When I get the chance, I was planning on testing it without the relay and just using a wire (i was getting there). To answer your question "Who advised you do this test (connecting 87a-30 of the FP relay)?"- Bob has been a big help to me doing this test thus far and he was the one who I have been working with who has been guiding me through the test. That said on this part, we have been trying to figure it out, I am not blaming him for anything, and as far as I aware, nothing bad happened that a blame needs to be issued for.
And personally, in response to "you are totally doing it the wrong way!!!!!" I think I am well along on the right track, using a direct wire lead from the two female terminals was the next thing I was going to try.
But that said, thanks for the help, and the wiring suggestions that you gave.
-Scott
Scott,
I read your post a few days ago when I was in Carmel, CA while enjoying the cool California breeze. When I saw that Bob was assisting you in your troubleshooting, I knew you were in good hands. In the short time I have come in contact with Bob, he has been very sharp and direct in his analysis.
When I asked you who suggested the test, it was just a figure of speech and was not expecting to get a name. At any rate, I consider Bob a very effective and helpful troubleshooter in this forum. He's a valuable asset and I have high regards to his abilities.
Tony
scott.k 08-25-2011 10:08 PM
Originally Posted by boyt911sc (Post 6218701)
Scott,
Tony
Oh ok, I see. I just wanted to make sure Bob wasnt being accused of anything because he has been very helpful. Thanks for clearing it up
-Scott
scott.k 08-25-2011 10:10 PM
Originally Posted by tirwin (Post 6218693)
Scott,
I just jumped it straight with wire. Maybe I should have used a fuse in case of an electricity surge? Well, it seemed to work with just a wire though
thanks
scott
Bob Kontak 08-25-2011 10:12 PM
Originally Posted by boyt911sc (Post 6218673)
Was there any particular objective why you suggested it?
Tony
It was a mistake but an honest one. See post 77 where I expanded a bit on the basis for the advice.
Thanks for the kind words also.
scott.k 08-25-2011 10:13 PM
bob, thanks, that would be very helpful
-scott
Bob Kontak 08-25-2011 10:21 PM
http://forums.pelicanparts.com/uploa...1314336060.jpg
Bob Kontak 08-25-2011 10:36 PM
You are in northern California. Redding, Ca is 75f now per weather.com That's 23.9C.
That's 2.3-2.7 bar. 33.8-39.7 psi cold control pressure (in that ball park). Bar is 14.5 and I was using 14.7. So correct psi is 33.4 - 39.2.
If it's 50F (10C) then the 22 would be at the low end of ok.
scott.k 08-25-2011 10:42 PM
to be honest, im not quite sure how the temperature works on that graph, so Im not sure how to compare it to my results. The graph is with the warm up regulator, so maybe the temp represents that of the regulator?
-scott
Bob Kontak 08-25-2011 10:47 PM
If you car is cold it is ambient temperature. Redding is 75 degrees so that is the "ambient" temp of your car.
Here is the converter and degress C are on the horizontal axis.
Fahrenheit to Celsius Converter
One bar is 14.5 PSI.
The dark band is the range of ok.
Once you plug the WUR in all bets are off because your WUR is not longer at ambient (cold).
The warm range is 3.2-3.7 bar. 47 - 54.
What is the temp outside there - or better yet - what was the temp where you car is. If it was 50F outside then 22psi is ok.
j911brick 08-25-2011 11:04 PM
The same applies if the motor is warmed up because it will heat the bi-metallic strip. SO you have a cold spec (for starting), and a warm spec (for once the motor has been warmed up).
Bob Kontak 08-25-2011 11:06 PM
Argh - It's 2:00am here.
Right now I see you car warming up to an ok range. Cold control pressure looks a little rich (low) but maybe not worth buying a new one this second.
Next time you check cold - make sure you know the temperature to use and then you can really dial in on the factory graph. The sun beating down on the engine lid would probably make the engine and WUR warmer than ambiant. Get it in the shade or garage. If the garage has AC that plays into the cold temperature that you test pressures against.
I will check back tomorrow.
Here's the link to all the wiring diagrams - well - for a 78 and 82 - the 82 is the diagram version I posted the link from earlier
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
scott.k 08-26-2011 12:29 AM
bob, thanks for the help, and i apologize if you were staying up late at night for this, you definitely shouldnt
this test that I just performed was all with the engine off at cold temperature
the outside air temp was 60, maybe even colder. Also, when its cold outside, the metal engine is always a bit colder than the air temp. Anyways, 60 degrees Fahrenheit, so thats 15.5 degrees Celcius, which means that the cold temp pressure (without the wur heated), 22 psi (1.5 bar) is low, but the temp with the wur warmed (52 psi or 3.6 bar) is spot on.
so it looks like ill move on to the next part of the test tomorrow
Bob Kontak 08-26-2011 05:55 AM
Cool.
I think the metal being colder than the air is just a perception. It just feels colder as it sucks heat out of your body faster than air. But hey, I've been wrong before.
I would do the cold pressure test again just for grins but live with a little richness on start up given the warm running specs.
However, I did just go back and read your symptoms. You definitely can't count it out (rich on start) for contributing to the stalling.
boyt911sc 08-26-2011 11:59 AM
Fuel pressures........
Originally Posted by scott.k (Post 6218687)
I just tested it out (with the gauge in line between the wur and the fuel dizzy with the valve on teh wur side).
Results:
22psi with wur unplugged
pressure rose from 22psi to 52psi when i plugged in the wur
i dont know what the pressure is supposed to be, but 22 seems low according to that video I posted earlier.
Scott
Scott,
These Bosch CIS WUR's in our cars are not precision devices but they work. Those numbers you obtained (22 - 52 psi.) are good numbers and your WUR is working. BTW, what is the problem you are trying to fix? I have not read the full thread (sorry). Thanks.
Tony
scott.k 08-26-2011 01:08 PM
Originally Posted by boyt911sc (Post 6219687)
Scott,
Tony
Tony, thanks for the help
My engine is running lean. I used to have to prime it with the flapper to get it to start, and then it would run until the engine heated up, and when the cold start shut off, it would fall into a choppy 400rpm idle.
Not, I cant even really get it running other than the occasional choppy low idle, it usually just dies out.
Scott
j911brick 08-26-2011 01:22 PM
Scott
Are you sure it doesn't have any air leaks? What is the condition of the O2 sensor system? Are you sure all the plugs are firing correctly? We may need to start from the beginning and start testing in systematic order.
scott.k 08-26-2011 01:35 PM
I know that an air leak could be the cause of the low idle, but back a while ago when I was testing this, everyone who gave advise basically told me to feel around for vacuum leaks, and if I couldnt feel any, then go through all of the fuel pressure tests to see if you can find the problem that way. So I bought the test kit, and I think now what I have it set up, I am going to go through all of the tests and if fuel delivery isnt the problem, then I guess the air box will come off and Ill check that thing for leaks. But I cant feel the air box leaking, and there is a toilet seat installed, so I am slightly doubtful of that being the problem.
THanks for the help
scott
as for your questions, im not sure about the shape of the O2 sensor?
and I think the plugs are firing correctly
scott.k 08-26-2011 01:40 PM
Originally Posted by ossiblue (Post 6018818)
Typically, fuel pressures are checked in the following order due to the need to have a "cold" engine for some of the tests: (gauge set hooked up between the fuel distributor and the wur, with the shut off valve on the wur side of the T)
1) System pressure check
2) *Cold control pressure You will need to identify the number on your wur and know the ambient temperature to perform this test. Someone will link you to the charts needed to check the cold control pressure, I'm sure.
Given your problem, this is the most critical pressure for you to check as too high a pressure will cause an overly lean cold start condition which may be part of your problem--this is the factor you want to eliminate before hunting down vacuum leaks.
3) **Warm control pressure
4) Residual pressure
*During the test for cold control pressure, be sure the wur is not energized. I am not familiar with your year system so I don't know if the wur is energized when the fuel pump is running (it is on an 82 but someone, please reply.) To be safe, you can simply unplug the electrical connector on the top of the wur.
**For the warm control pressure, you must have the wur energized and observe the increase in pressure until it stabilizes. Again, my lack of knowledge will require someone else to help here. You can simply plug the connector back into the wur or, if the wur doesn't get current while the fuel pump is running, you can simply use a jumper wire from a know voltage source to the terminal on the wur.
As for order of vacuum leaks, all areas are equally suspect. I would follow the order of checking the most easily accessible hoses and components first and move on from there.
So according to this post on page three, I have gone through the first three of these?, and I have the last one left, and to be honest, Im not quite sure how to do that test. But once I do the "residual pressure" test, I will know that it isnt a fuel pressure problem?
Scott
