LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
80Targa's Avatar
SC Idle Problem
Looking for help with idle problem. After starting cold, the idle ocillates from 0 to 2000. After it warms up by applying the throttle to steady the idle for a minute or so it will idle at 900. The first few miles driven thereafter it tends to stall when decelerating. This problem happens at about 3000' elevation at 55 degrees. At sea level at 70 degrees it starts and idles normal. I just purchased this car so I'm new to the CIS system. and am hoping someone can narrow down the seemingly many possible problems.
Old 02-01-2002, 07:51 PM
wckrause's Avatar
You should get your mixture set using an exhaust gas analyzer. See if you have the same symptoms. I'm guessing you're running a little rich, which will only get richer as you go up in altitude.
Bill Krause
We don't wonder where we're going or remember where we've been.
Old 02-01-2002, 08:18 PM
Senior Member
Doug Zielke's Avatar
Welcome to the brotherhood of SC ownership, 80Targa!
Bill Krause has already posted a suggestion for you, and if you want to master the Confounded Injection System (C.I.S.), I'd suggest reading Probst's book on Bosch Fuel Injection. Our host (Pelican Parts) can get it for you.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 02-01-2002, 08:41 PM
