Cheap Hardware cleaner
It is always nice to have clean hardware when you are reassembling or servicing your car but cleaning, nuts, bolts and washers tedious at best. I having a harder time with the small parts because of the onset of Parkinson's. I have lost much of the dexterity in my hands so it makes handling small nuts and bolts difficult.
That said, I came up with a solution. I took a small water bottle, 16 ounce, and filled it half full with a 50/50 solution of Simple Green and water. All you need to do is shake it! If you use the water bottle as a way of organizing your hardware during disassembly it will have time to soak. I hope this is of value to someone.
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... |
Canucks Fan
We have a product in Canada called CLR, calcium, lime, rust, I soak that kinda thing in there over night and wipe them clean in the morning, works great.
Finn |
Recreational User
We have CLR in the states too. I never thought of using it for this purpose.
I can confirm CLR works great but be careful as it will quickly remove the cadmium plating on hardware.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
Great idea - I force myself to put the hardware in old medicine bottles that I label. Now the bottles can get double duty. Thanks.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
I use diesel, then Super Clean, finish with dish soap for really dirty parts. Larger parts benefit from a wire cleanup brush and Brakleen or similar solvent. Small throway brass brushes are great for small parts and hard to clean areas.
Easily Confused
In the spirit of diesel, I use Kerosene. It dries clean and is easy on rubber/soft parts.
I used to use it on motorcycle O-ring chains with good results. The brass and nylon brushes are great, too.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
Try one of the citrus-based, water-soluble cleaning liquids, a parts basket, stiff parts brush and a large bucket.
I use a product called "Oil-Eater", available at most industrial supply houses; also at Costco if there's one near you. Can be diluted for general purpose cleaning chores. Costco Business Center: A different warehouse designed to meet the needs of your business. Sherwood (no affiliation) |
