Reverse goes forward?
When I have my car in reverse gear it goes forward. Any one have that happen to them. Any ideas?
Thanks in advance
Jason
1972 911T MFI
1995 911 C2
Old 01-23-2011, 10:48 AM
Kantry Member
oldE's Avatar
Jason,
Did this just start happening?
Has the transmission been out of the car, or have the shift bushings been replaced?
Could be something has slipped and you are actually getting the next gate when you are seeking reverse.
Les
Best
Les
Old 01-23-2011, 10:58 AM
300hp 1800lbs is the goal
pksystems's Avatar
Did 72 have the dogleg 901 transmission?
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 01-23-2011, 11:11 AM
It started happening about a month ago. It was working fine before. I have never taken the trans out but I don't know if the previous owner did. I replaced the bushings a few years ago. I will see if those are warn again. It seems to rub in the bushings area when shifting from 1st to 2nd.
My reverse is all the way to right and back. Is that the 901 dogleg?
1972 911T MFI
1995 911 C2
Old 01-23-2011, 12:03 PM
sudo apt-get purge 930
equality72521's Avatar
When it goes forward is it really sluggish like you're in 4th gear? Might be loose and out of adjustment putting you in 4th instead of reverse.
--clutch-monkey
Old 01-23-2011, 12:21 PM
pksystems's Avatar
Okay if it was working fine, then it's not a 901 (has reverse where 1st is on newer tranny)
Thought maybe car was new to you, and '72 is start of newer shift pattern
901 has reverse top left, down to 1st
Old 01-23-2011, 01:10 PM
LJ851's Avatar
Perhaps someone is playing a trick on you and flipped your ring gear? How many gears go in reverse?
Old 01-23-2011, 02:02 PM
Oh Haha's Avatar
Check the shift coupler between the rear seats. I would be willing to bet the cone screw is loose. The shift rod has moved enough to throw off the pattern.
Adjust the shifter rod back to normal and tighten the set screw, using a drop of thread locker this time.
Pacific Blue
Wayne
Old 01-23-2011, 03:22 PM
Reverse is probably still there, but you have to be able to select it.
Sounds like excessive wear in one or more shift linkage bushings. There are three bushing areas. Bottom of shift lever, front of shift tube and shift coupler. Remove the access cover in the rear tunnel and wiggle the shift lever while observing the shift tube. If you don't see the shift tube move in concert with the shift lever, go to the threads that discuss and demonstrate how to replace them.
Hope this helps,
Sherwood
Old 01-24-2011, 10:37 AM
Could also be the adjustment of your shift forks, which luckily could be rectified with the trans still in the car. As I understand it, the shift fork tries to grab two gears at a time, resulting in the 1st versus Reverse situation. We had originally thought that this was the problem with my car, but in my case, I had cracked second gear in half.
Hopefully, someone on this board will be able to provide a better explanation than my feeble attempt.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 01-24-2011, 11:24 AM
Most likely you have 1 for Reverse and 3rd where 1st was.
The Bushings are only Plastic and wear out easily if the Set Screw is not loose like the above person described.
Remove the 4 screws on that inspection Cover and see if you have either play from the Entire assembly loose on the SHaft or the Bushing out which allows the Shifter lever to move more but not in the transmission.
I am betting on this!
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 01-24-2011, 02:16 PM
Ok it was the bushings under the shifter. I had replaced the cup one a few years ago but not the doughnut looking one cuz it was ok at the time. Man is that one hard to put in. I had to heat it up in a cup of water and push it in with a screw driver. It really really improved my shifting. Much smoother less sloppiness. So I guess it was going into fourth before instead of reverse. Thanks for your help everyone.
1972 911T MFI
1995 911 C2
Old 01-25-2011, 06:52 AM
Oh Haha's Avatar
Sweet!!
Pacific Blue
Wayne
Old 01-25-2011, 04:04 PM
