-   -   build thread - my version of a mini-duck for longnoses. (http://forums.pelicanparts.com/porsche-911-technical-forum/587500-build-thread-my-version-mini-duck-longnoses.html)
haycait911 01-23-2011 08:15 PM
fuctionality aside, I've never been thrilled with the look of the ducktail on un-flared cars. I had one on my SWB for a bit but it was a bit much. I like the shape, just not the size. also,on the sides it just looks 'heavy'. my thought is to use the basic shape, but less of it.
I came across a less-than-stellar duck yesterday ( thanks Duane ) . so time to have at it. I cut off the tail from the decklid. after a couple of additional trimming cuts here's where I'm at. I'm liking it so far. I'll post additionally as the project progresses so subscribe away.
http://forums.pelicanparts.com/uploa...1295842293.jpg
http://forums.pelicanparts.com/uploa...1295842321.jpg
http://forums.pelicanparts.com/uploa...1295842342.jpg
http://forums.pelicanparts.com/uploa...1295842375.jpg
http://forums.pelicanparts.com/uploa...1295842443.jpg
village idiot 01-23-2011 09:20 PM
That's a neat concept. Can't wait to see your progress:cool:
911Freak 01-23-2011 09:32 PM
+1 Sub'd SmileWavy
haycait911 01-23-2011 09:53 PM
here's as far as I got tonight. pretty close to what I'm looking for. a little more trimming, some prep and I can panel bond it on. then start the bodywork/fairing. updates will continue. D.
http://forums.pelicanparts.com/uploa...1295848215.jpg
http://forums.pelicanparts.com/uploa...1295848250.jpg
haycait911 01-23-2011 10:15 PM
which mount point are you guys likin'
A 'tuner-car tail' http://forums.pelicanparts.com/suppo...s/pukeface.gif
http://forums.pelicanparts.com/uploa...1295849279.jpg
B 'low-rider' http://forums.pelicanparts.com/suppo...leys/shake.gif
http://forums.pelicanparts.com/uploa...1295849364.jpg
C 'middle of the road' ;)
http://forums.pelicanparts.com/uploa...1295849440.jpg
D 'high and tight' :)
http://forums.pelicanparts.com/uploa...1295849551.jpg
personally, I'm leaning toward D, although C is probably closer to the stock location. any thoughts?
village idiot 01-23-2011 10:55 PM
Roll it out into the open and lets see the same shots from a better distance:D
Jack Olsen 01-23-2011 11:45 PM
I would go with D. High and tight.
Flieger 01-23-2011 11:46 PM
Maybe there is something to the A position? :confused:
<a href="http://www.flickr.com/photos/max_911_fahrer/5233335599/" title="POC Racing Willow Springs 2010.12.04_late 146 by Max_911_fahrer, on Flickr"><img src="http://farm6.static.flickr.com/5162/5233335599_61f16ec832_z.jpg" width="640" height="480" alt="POC Racing Willow Springs 2010.12.04_late 146" /></a>
Brad394 01-24-2011 04:04 AM
Great idea... was thinking much the same thing but starting with a 964 lid - a la Singer - I am thinking maybe the mid position much like the 996 GT3 , minus the blade wing. Keep up the good work.
Brad
drcoastline 01-24-2011 04:59 AM
D no question
euro911sc 01-24-2011 06:18 AM
I'm not sure I like the idea at all... I'm kinda with you that no flares makes tails look bad and you should have no tail on a narrow body car... I also agree that we need some distance shots to fully eval the whole look from side to rear qtrs before making a choice ;)
You may be doing yourself an injustice with out the whole car together. It may not look like you planned when the bumpers get back on it!
So I reserve the right to change my mind ;)
-m
175K911 01-24-2011 06:32 AM
Singer 911
The Singer has a small duck, and it's still in the same position as the original one:
http://forums.pelicanparts.com/uploa...1295879551.jpg
tobluforu 01-24-2011 07:06 AM
How about mounting it right below the rear window, or even above it like on the roof, that should work ;).
I also think that if you are going to do this that you should cut it down more because it will be hard to tell the difference unless pointed out.
fritzgator 01-24-2011 07:28 AM
D. I think the line of the grill flows nicely into the quack.
techweenie 01-24-2011 07:50 AM
Interesting project! I agree, a couple more photos at a distance would help, but high and tight is the easiest to like immediately, because it's closer to stock.
Hard to know what the best aero solution is, though, and the best esthetic solution is rarely the best aero solution.
Wil Ferch 01-24-2011 07:52 AM
From an "effectiveness" standpoint.....high and tight is the way to go.
skinnerd 01-24-2011 07:54 AM
Keep it close to stock.
There's a reason it was located there from the factory....
Eric Hahl 01-24-2011 08:27 AM
C or D look great to me but in the end, it's your ride, you gotta love it. Great to see people leaving the box so to speak.
tharbert 01-24-2011 08:30 AM
I've always wondered about duck tails holding water while parked. I know a little water isn't going to be a problem especially if it's a fair weather car. But "D" looks to me as if it might hold a bit more standing water right below the grill than a more traditional duck? Or is this even a consideration? Otherwise, high and tight looks more "right".
Doug&Julie 01-24-2011 09:27 AM
+1. Can't wait to see the finished product!
