-   -   Inner Door Handle Question (http://forums.pelicanparts.com/porsche-911-technical-forum/587893-inner-door-handle-question.html)
sobamaflyer 01-25-2011 03:41 PM
Will the inside slim armrests/handle with pushbutton door opener from a 1970 bolt up to a 75 without major modification?
Thank you, Travis
ossiblue 01-25-2011 03:57 PM
Thank you, Travis
1970 cars had a pull lever opener similar to that on 75 model cars. What you appear to describe is the earlier armrest from 67 and earlier (maybe 68 too) that had a small push button at the front of the armrest. Whether or not the early style will work, I don't know for sure.
sobamaflyer 01-25-2011 05:18 PM
http://forums.pelicanparts.com/uploa...1282417817.jpg
Here is the image from the For Sale ad here in Pelican, it states it's on a '70 Targa so?
Long Nose 01-25-2011 10:21 PM
I have a 70 911T and a 67 912 doner. The door handle in the 67 is as pictured above, while the 70 has a mechanism that is similar to later models. I would guess that the inner door mechanism is the same, but there may be minor differences with the exterior mechanism.
sobamaflyer 01-26-2011 02:39 AM
Did Porsche maintain the mounting locations (the welded in nuts) for the upper & lower portion of the handle?
In that picture it looks farther forward and my guess is that they are probably different?
