-   -   Carrera RS Script (http://forums.pelicanparts.com/porsche-911-technical-forum/58812-carrera-rs-script.html)
rstrahota 02-02-2002 05:16 PM
Carrera RS Script
Does anyone know where I can get artwork of the "Carrera" script as used on the sides of the 1973 Carrera RS? Smaller-scale would be preferred. I know the decals are comercially availible, but I have something else in mind...
dad911 02-02-2002 06:14 PM
I have them scanned in for a 'vinyl cutter', but it uses its own file format. What size do you need?
Fishcop 02-02-2002 07:25 PM
Dad, can your "carrera script" file be sent via net or floppy/disc? I've been thinking about getting the script for my car, but was considering another colour combination other than what is available from factory. Is this possible with the vinyl cutter file?
Cheers
rstrahota 02-03-2002 04:18 AM
Carrera Script file
Hey, dad...
I would take it in waht ever file you have. Could that file be emailed?
If yes, strahota@optonline.net
ds
dad911 02-03-2002 06:03 PM
1 Attachment(s)
I saved it as a dxf. Let me know if this works. (zip file attached)
micheloaks 10-17-2009 11:14 PM
Carrera Script
Hi downloaded and opened the DXF file though nothing happened.
Does anyone have a carrera script saved as a font or some other format? Both earlier styles I am looking for.
thanks Michel
Canada Kev 10-17-2009 11:43 PM
If you have it in .dxf, you should be able to export to a .eps. This is a vector file that will be useable by any sign cutter or designer. It's pretty universal.
dw1 10-18-2009 07:17 AM
dad911 -
Thanks for posting the .dxf file. I've seen this in .bmp, jpeg, etc., but not in a standard file exchange cad format.
Very helpful for scaling, and even extruding to 3d using standard cad s/w.
Again, thanks.
dad911 10-18-2009 07:58 AM
Your welcome. Old thread.......
dw1, do I know you? NNJR?
group911@aol.co 10-18-2009 08:03 AM
Is that font available? I'd like use the same font to spell something different.
