Question Carrera RS Script
Does anyone know where I can get artwork of the "Carrera" script as used on the sides of the 1973 Carrera RS? Smaller-scale would be preferred. I know the decals are comercially availible, but I have something else in mind...
Old 02-02-2002, 05:16 PM
Platinum Member
dad911's Avatar
I have them scanned in for a 'vinyl cutter', but it uses its own file format. What size do you need?
Old 02-02-2002, 06:14 PM
Bird. It's the word...
Fishcop's Avatar
Dad, can your "carrera script" file be sent via net or floppy/disc? I've been thinking about getting the script for my car, but was considering another colour combination other than what is available from factory. Is this possible with the vinyl cutter file?
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 02-02-2002, 07:25 PM
Question Carrera Script file
Hey, dad...
I would take it in waht ever file you have. Could that file be emailed?
If yes, strahota@optonline.net
ds
Old 02-03-2002, 04:18 AM
Platinum Member
dad911's Avatar
I saved it as a dxf. Let me know if this works. (zip file attached)
Old 02-03-2002, 06:03 PM
micheloaks's Avatar
Carrera Script
Hi downloaded and opened the DXF file though nothing happened.
Does anyone have a carrera script saved as a font or some other format? Both earlier styles I am looking for.
thanks Michel
Old 10-17-2009, 11:14 PM
Formerly known as Syzygy
Canada Kev's Avatar
If you have it in .dxf, you should be able to export to a .eps. This is a vector file that will be useable by any sign cutter or designer. It's pretty universal.
Kevin
Old 10-17-2009, 11:43 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
dad911 -
Thanks for posting the .dxf file. I've seen this in .bmp, jpeg, etc., but not in a standard file exchange cad format.
Very helpful for scaling, and even extruding to 3d using standard cad s/w.
Again, thanks.
Old 10-18-2009, 07:17 AM
Platinum Member
dad911's Avatar
Your welcome. Old thread.......
dw1, do I know you? NNJR?
Old 10-18-2009, 07:58 AM
group911@aol.co's Avatar
Is that font available? I'd like use the same font to spell something different.
Thanks,
Bob
group911@aol.com
Old 10-18-2009, 08:03 AM
