john79sc's Avatar
O2 sensor control unit wiring
I installed a 1980 engine in my 79sc I am mounting and routing wires for oxygen sensor control unit and i need to know where harness is routed from under passenger seat into luggage compartment
any help would be appreciated
Old 01-27-2011, 04:22 PM
Wire harness routing.......
John,
There are two (2) sets of wiring harnesses you need to route through. The 2-wire wire harness (shown above) goes under the dash and toward the front fuse panel. The red wire goes to fuse @18 and the red/white wire goes to FP relay @ 30 connection. The main wire harness for the ECU goes toward the engine bay. You need to open up a hole for the harness to get through the firewall. It would be helpful to could find a similar car and look where the hole is located. Keep us posted.
Tony
Old 01-27-2011, 06:33 PM
john79sc's Avatar
Tony I already ran the rear section of the harness to the engine I also have wiring schematic showing connections at fuse box,what I don't have is another car to see where underdash the two wire harness goes through to the fuse box
Old 01-27-2011, 07:08 PM
Routing under the dash........
John,
A friend gave me his '80 ECU but had to take it off from his car. So I traced and inspected the wire harness and located the terminals. Unhooked them and carefully and gently pulled the harness from inside the car. From the trunk side, locate the rubber grommet that could accommodate additional wires to pass through. There several holes available to get the wires to the front. The rear harness needs more effort than the front harness to install. So I don't see what's the difficulty threading the wires to the fuse section.
Tony
Old 01-27-2011, 07:35 PM
The 2 wires need 12 volts each..
Bruce
Old 01-27-2011, 07:54 PM
john79sc's Avatar
I know there are several places to run the wires I was just curious as to how they are originally routed.Does it go through the grommet from the a/c switch or is it routed across and go through behind instruments?
Old 01-27-2011, 07:57 PM
john79sc's Avatar
Thanks bruce I know that the red wire gets constant power from the interior light fuse and the red wire goes to the # 30 terminal at FP relay I was hoping someone had their carpet up and could show or tell me where that two wire harness goes into luggage compartment. Thanks guys.
Old 01-27-2011, 08:07 PM
john79sc's Avatar
Correction, red/white wire goes to FP/wur connection from relay
Old 01-27-2011, 08:10 PM
