Luxter's Avatar
Question What 2 do after 4 years of storage?
Dear fellows,
Friend of mine inherited a 1975 Anniversary Edition silver 911. It has been stored in his garage for last four years or so without seeing daylight. I can only imagine that tires got flat spots, gas in tank must look like sauerkraut and oil to match it in its reservoir. He claims that there is a leak of some sort (I didn’t get to see the car yet) on the driver side of the car, possibly power steering, judging by his description and color.
What would you recommend to do before bringing this silver beauty back to life.
I imagine oil change would be in order followed by fuel tank flush, brakes flush.
All constructive suggestions are welcome.
Any similar past experience anyone?
Many thanks in advance,
Luxter
Old 01-31-2011, 10:46 AM
HarryD's Avatar
Luxter,
There are many threads on this topic. A search will turn them up.
Try search terms like:
Starting stored car.
Look for posts by Grady Clay (one of our Gurus).
This thread may be helpful to you: Winter storage checklist?
Originally Posted by Grady Clay View Post
Winter or long term storage.
First let me reinforce what Randy said. All automobiles fair best when regularly driven. If that can only be a nice dry winter day every week or so, then so be it. The key is keeping or getting it dry and absolutely no exposure to salt (or Magnesium Chloride.)
Putting your 911 back in service.
This is just as critical as the storage technique.
Put in new hot plugs. I would use BP5ES but some recommend hot recessed-tip plugs (like some race plugs) to prevent fowling. You want to do everything possible to have the engine fire and run properly on the first try.
Treat it lust like a brand new engine. It will need careful break-in.
Oil the cylinders, cams, etc. and turn over the engine with a wrench on the crank pulley. Turn two or more revolutions and make sure there isn’t hydraulic lock.
Install fresh fuel high octane fuel with some 2-stroke oil in it.
Make sure the fuel system is working properly.
Make sure the ignition system is working properly.
Some use a spare muffler and cat bypass for start-up as it will get oiled.
Start and run at as low RPM possible for 15 seconds. Let sit for 15 minutes. Repeat, extending the running time but keep RPM low. Gradually bring up to normal running.
Never run the engine at high RPM.
For first drive you want to give it some power but not run it longer than a couple of minutes without a “rest.” Again, extend the running time with increasing high power (not high RPM.)
The theory here is that there are localized high friction areas that get hot during this re-break-in process. You don’t want anything to get too high temperature and induce failure or have exceedingly high ware. When under power, the rings seal (mostly) from cylinder pressure. You want them to re-seal asap but not get overheated. High RPM will overheat the rings in a flash and the high friction can over stress the ring lands in the pistons. Some of the other areas are the cam-to-rocker surfaces, chain links, rocker-to-shaft, chain idler sprockets, and more.
This situation is far more delicate than a new engine brake-in procedure. Treat this just like a fresh engine but extend the break-in and be even more careful.
What to do with a 911 that wasn’t preserved for storage?
Drain the fuel from the drain port in the tank. Don’t run the fuel pump. If necessary (probably) clean the tank and outlet filter screen
Buy a new battery.
Change the oil and filter, clean sump plate.
Remove the sparkplugs and inspect with a light or bore scope. If the cylinders are rusty don’t turn the engine, go to Plan B.
Remove the intake valve covers and inspect for rust. If the cam is rusty, go to Plan B.
If you suspect there is corrosion in the oil sump tank, remove it and clean or replace it. Those rust flakes go directly to your bearings without a filter.
If everything appears OK, proceed as above but even more carefully.
Plan B and what to do with a 911 that has been stored for several (many) years?
Don’t try and start it! You may do far more damage to it in one minute than 100K mi. of driving.
In most cases it is best to just remove the engine and trans and do a maintenance overhaul.
Often the brake master cylinder has failed (or will after a few applications of the brakes.)
Old tires should be replaces with new.
Get the old battery out asap.
Electrical connections may be an issue and need to be cleaned.
Fuel and ignition system components will need cleaning or replacement.
Chain tensioners that sit for long are an issue for any engine.
What to do after your 911 is back in service.
Nice extended calm tours will get everything friendly with adjacent parts.
Change oil regularly. Check the sump screen for anything unusual.
Use higher than necessary octane fuel until the rings are fully seated.
Keep an eye on brake fluid level and possible fluid in the pedal assembly.
Inspect for any signs of tire failure, inboard and out.
As things change, bring them back into spec. If something fails (wheel bearing, CV, door latch, window regulator, hood lift, etc. – fix it. You want to keep your 911 in top form.
If it ever seems to loose power under acceleration – STOP. Find out why. You never want to have a rod bearing failure turn into a rod failure, broken case, and worse.
I’ll reiterate what many have said: The best and most reliable 911s are those that are driven regularly. Those that sit for extended periods are destined to have more problems. If you store your 911 out of personal necessity or adverse driving conditions, it is worth the effort to store it properly.
Best,
Grady
BTW, here are some links:
Storing and preserving an engine - Pelican Parts Technical BBS
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-31-2011, 11:28 AM
Luxter's Avatar
Thank you, that's a good start.
Appreciate.
L
Old 01-31-2011, 11:53 AM
French Import
zippy_gg's Avatar
No power steering on that car, but I strongly suspect the leak comes for a failed brake master cylinder. Not uncommon for that age, and not difficult to resolve.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-31-2011, 03:26 PM
