-   -   Lambda sensor location on SSI heat exchangers (http://forums.pelicanparts.com/porsche-911-technical-forum/588934-lambda-sensor-location-ssi-heat-exchangers.html)
HenrikL 01-31-2011 01:37 AM
I got a good deal for a pair of SSI heat exchangers. The SSIs are intended for MFI and has no lambda sensor.
The MFI pre-heat pipe is just to remove and weld up the hole, but I wonder where to put the lambda sensor? Does anyone have a picture of where the lambda sensor is located on SSI heat exchangers?
SpeedracerIndy 01-31-2011 07:08 AM
Looks like it's on the drivers side pipe, just after the collector.
I stole this picture from another thread.
http://forums.pelicanparts.com/uploa...1154444957.jpg
HenrikL 01-31-2011 01:47 PM
Thanks! Seems to be a lot of room in the area.
don gilbert 01-31-2011 03:32 PM
make sure you get the angle rite, or valve cover will be hard to get off. and use anti seize on the new bung, if not, the threads will come out of the bung on your next 02 service. would be a good time to replace sensor too, bosche one wire at oriellys for 20 bucks.
