HenrikL's Avatar
Lambda sensor location on SSI heat exchangers
I got a good deal for a pair of SSI heat exchangers. The SSIs are intended for MFI and has no lambda sensor.
The MFI pre-heat pipe is just to remove and weld up the hole, but I wonder where to put the lambda sensor? Does anyone have a picture of where the lambda sensor is located on SSI heat exchangers?
1977 911 2.7 Stock restoration in progress
Old 01-31-2011, 01:37 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
Looks like it's on the drivers side pipe, just after the collector.
I stole this picture from another thread.
1981 SC ROW Coupe
Old 01-31-2011, 07:08 AM
HenrikL's Avatar
Thanks! Seems to be a lot of room in the area.
Old 01-31-2011, 01:47 PM
grateful user
don gilbert's Avatar
make sure you get the angle rite, or valve cover will be hard to get off. and use anti seize on the new bung, if not, the threads will come out of the bung on your next 02 service. would be a good time to replace sensor too, bosche one wire at oriellys for 20 bucks.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 01-31-2011, 03:32 PM
