RS speedo ident?
Hello,
anyone know if this speedo was used only in RS cars, or was it installed in other 911 too? ![]() thanks Falk
87 930 bblk/blk 88 3.6 white/blk |
930 turbo??
Okay, I'll ask because I just don't know. What's with the redline between 50,60 kph?
It is the speed limit in the european city
No, this speedo is in a 1970T targa, for sure it belongs not to the car.
I found some info that this was used in the RS, but I have no info if it was used elsewhere. Falk
It would only have been used on the '72 - 75 911 2.7RS, all the turbos use electric speedos
there were 3 versions, 1 for those cars w/ 215/60x15 tires and another for cars w/ 225/50 x15 tires and a 3rd version for Japanese cars
Bill,
thanks for the info! When I get this thing out there, I will try to find some numbers on the back. Falk
Yes - check the # up at the top of the face - that will tell which one you have
David G PCA '72 S/T '74 Euro Carrera '95 RS --SOLD '77 930 Steel Slantnose "Wedgie" '57 Speedster planter Breeding family of Volvo/ BMW Wife + kid mobiles 'Rib-Breaker' '01 CRG 125 shifter kart Aprilia RS50-weedeater with fairing |
That would have been used in '74-'76 Euro 2.7 Carrera (in most markets - others used the equivalent 180 mph version) & '74/'75 3.0 RSR - earlier cars had the version with the central silver 'button'.
Andy M&W 904 ... now gone GT-style 356C ... also gone |
the rs 2,7 has the silver button.... I quote 2,7 carrera
For sure the '73RS has a silver center button
![]() The 300km/hr version of the electric was used on 930 and Carrera 3.0 here's mine after conversion to mi/hr
Hello,
I found the time to check the speedos part nr: #91164150329 Can be 2.7 Carrera too, difficult to get exact info... Maybe someone here know more about this? thanks Falk
Almost Banned Once
Good looking speedo. I'd use it...
- Peter |
But a 74 speaker grille ![]() Regards Mike
RS #1551 (Sold) 67S |
911.641.503.00 0-300km/h used from '72-73 w/ 215/60 x15 tire(silver center) 911.641.530.00 0-300km/h used from '72- w/ 225/50 x15 rear tires 911.641.503.29 0-300km/h used from '74-76 911.641.507.00 0-300km/h used from '74-75 Japan Electric 911.641.532.00 0-300km/h used from '76 w/ 215/60 x15 rear tires 911.641.539.00 0-300km/h used from '76 Japan 911.641.501.00 0-300km/h used from '76 w/ 225/50 x15 rear tires(black center)
