Length of steel braided oil line for front oil cooler?
Gents,
I am planning to install a front oil cooler behind my RS front bumper. I recently pruchased a RSR style oil cooler with AN-12 fittings welded on one side of the cooler. I have a 1980ish VGC thermostat. Question: I plan to buy 20 feet of AN-12 steel braided oil line. Is that enough , too much or little? The cost is $6.15 per/ft. Thanks -- Vr,
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
i am in the middle of the same project asnd plan on removing the trombone and running my lines tomorrrow. i plan on running them from the trombone connections to the cooler only. Why do you want to run all the way back to the thermo? I bought the 30mm/12an fittings from pegasus. Dont think youll need more than a few feet for each hose. ill let ya know how it goes and post some pics.
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
BAT/ Mocal supplies 30foot of hose when you order a kit...
Roland 930 Turbo '81 Too many modifications to list |
Senior Advisor
There (BAT) thinking you don't have a fender oil cooler, do you have one? If you do, than you only need a few feet of hose. They have the correct fittings for that.
08 Cayenne Turbo |
Sherwood |
If you must use -AN, which is pretty expensive (-16AN right angle swivels are like $40 each), use Aeroquip startlite. The braided hose is not only heavier, it will abrade everything it comes in contact with.
I highly recommend sourcing used NASCAR hoses, there's a chap named Page Lemon at Race City Race Parts who sells on eBay-- I used all used Startlite hoses in -16AN for my cooler, worked great at a fraction of the new price. If I had it to do over again I would use 30mm factory Cohline throughout. S/T style.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I get all my Aeroquip hose and fittings from Pelican Parts in WI. Have all the -12 and -16 fittings in stock, as well as the metric to AN adapters.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Thanks for the respones.
Sounds like 20-30 feet is required, from the above posts. I'll get calling around for quality hoses and prices. Update - I have a stock 1970T with a 2.4 motor w/o a front oil cooler. I will need to run oil lines all the way from the VGC porsche stock thermostat. The picture that Scott shows of his front oil cooler is the exact oil cooler I bought for $300 shipped from a man in CA. He builds very solid oil coolers and you can select the size fittings, which he welds on. I picked the male connector for size 12 female connector. I need to fab a bracket. Scott and others, pls post a few close-ups of yours! Thanks,
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 Last edited by bavaria911; 04-01-2010 at 08:01 AM.. |
Home depot 3x3 L bracket. I opened the holes so the M8 harware for the threaded inserts would fit thru. Used a bigger L for the underside with a rubber grommet between the bracket and the cooler.
Here is tip one on this cooler. Be VERY VERY careful putting on the AN fittings the first time. GREASE THEM UP!!!!! I turned them on a few turns ...BY HAND... and the fitting screwed up the threads. I wasnt being gorilla hands and i did not wrench them on. Spent the next hour praying ang cleaning up the threads. Tip two: use 45 deg fittings on the cooler. I tried straights and they hold the bumper out in the front. the 45's pull the line in toward the body quicker. Just what ive learned today. ![]() ![]()
It appears your front oil cooler has 2 x 45' degree AN fittings.
Hows is the project coming. I plan to buy the steel braided lines from a compamy in VA, at $6.10 p/ft. They sell in bulk all over to race firms. Their AN fitting for -12 rin $10 for straight to angled 45-90 degrees all under $25. Vr,
So far so good. Waiting on the SS mesh from Pegasus to finish the install. Had to play with fittings and fitment. Yes, they are 45's. Had a slight rub issue with the straight ones. Those prices look good, slightly cheaper than ebay.
gduke2010
20' sounds like to much. Call chuck at Elephant Racing, he'll send the right amount and can give good advise on installing the hose. Thats were I bought mine. Everything worked out perfectly.
Carmagic.us
What type of oil cooler is this ?
I'm looking for options for my 3.6 conversion. Thanks
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
RETIRED
I have AN fittings and conversion from Metric to AN fittings....as well as an extra cooler that you can use in the fender well along with the front cooler.....
PM me.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Is nobody bringing up the question whether or not -12 line is fat enough? I thought the common wisdom was -16 for a front-cooler install. Wasn't that also Bruce Anderson's warning/mantra all along ??
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
+1 Call chuck at Elephant Racing..
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
I decided to go with AN-12 SBH.
Here are some pic's of the oil cooler test mounted on my car: ![]() ![]()
you test fit the bumper over the cooler for placement? looks a bit high. diference in early body with RS bumper and SC body with RSR bumper? BTW it works awesome. My temps at Watkins Glen in the summer dumped. Barely even moved the gauge where year prior it was runnin past halfway.
latest pic i had. isnt the cooler opening in the same place as your rs bumper?
