Is there aBolt In Roll Bar with removable cross brace?????
Been looking at Das Sport bolt in roll bars but it appears a pain to keep taking in and out so the rear passenger area can be used when not at a DE.
Does anyone make a bolt in roll bar........that the main hoop can be left in place....but remove the diagonal and harness bar so the rear passenger area can be used? |
Auto power.
Check Safety Devices. Mine fits very well in the car. However, I have the fixed cross brace.
Depending on what you want to do (Race, DE etc) make sure they have the correct specs. I heard that some people had problems with Safety Devices cages not passing SCCA tech.
YMMV |
911
Its for PCA DE use only.
Cross brace will be removed for street use |
Safety Devices. Their stuff is expensive but they are the best IMHO. They tie into the body better and with proper weld in bolt plates.
G Roll Bar, 911 Coupe -1989 PCA Legal-Stable Energies |
Safety Devices Install - with removable seat back cross brace.
I thought my croos brace was a welded in piece but I am a moron today..... Too dang cold here to think straight To get everything properly lined up you do have to put the cage in and out several times if you want a real nice fit. I installed mine without the floor ("frame rail") plates first and marked all the holes to be drilled. I then drilled the "rails" for the plates, set them in place and re-installed the cage. I then bolted the plates to the cage floor plates and tack welded each plate on four corners to the frame "rails". This insured that the cage was exactly where I wanted it to be. I then removed the cage and did all the final welding. After that it was time to put the cage in for the last time and leave it..... http://forums.pelicanparts.com/uploa...1296765043.jpg http://forums.pelicanparts.com/uploa...1296765063.jpg http://forums.pelicanparts.com/uploa...1296765088.jpg http://forums.pelicanparts.com/uploa...1296765105.jpg http://forums.pelicanparts.com/uploa...1296765123.jpg http://forums.pelicanparts.com/uploa...1296765142.jpg |
Plates welded and sealed:
http://forums.pelicanparts.com/uploa...1296765289.jpg http://forums.pelicanparts.com/uploa...1296765303.jpg Here are the pics of how tight this fits in the car: http://forums.pelicanparts.com/uploa...1296765374.jpg http://forums.pelicanparts.com/uploa...1296765412.jpg http://forums.pelicanparts.com/uploa...1296765430.jpg http://forums.pelicanparts.com/uploa...1296765446.jpg http://forums.pelicanparts.com/uploa...1296765465.jpg |
| All times are GMT -8. The time now is 02:46 PM. |
