gzulli's Avatar
84 3.2 cold weather noise
I have an 84 Carrera 3.2 that when the weather gets down to the 40's here in PA the car makes a squelling sound in the engine compartment behind the rear seat, passenger side. If you stand outside the car you can't hear the sound over the exhaust. The sound will eventually diminish (maybe as the engine warms). It sounds like a valve or a pump of some sort. I saw a mention of a cold start valve and wondered if this is what I hear. It sounds like it is in the area of the airbox. Am I hurting the car by driving and or is this something that needs immediate servicing? Thanks.
1984 911 M491
2014 Accord
1997 854 GLT (Kids safety car)
Old 11-03-2004, 04:11 PM
ausgezeichnet's Avatar
Sure it's not your fan belt or A/C belt if you have A/C?
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 11-03-2004, 05:08 PM
abit off center
cgarr's Avatar
Is it only when your heat is on? My heater blower is going bad and will squawk until it warms up. But thats on the left side.
Craig
______________________
Craig
G2Performance
Old 11-03-2004, 05:40 PM
Designer King
Paulporsche's Avatar
If not those, then maybe a heater blower?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-03-2004, 05:46 PM
gzulli's Avatar
It seams to happen when the heater is not on, usually at the start up. I do have AC but wouldn't the belt be acting up in warm weather also? It really does seem to happen when the temps hit 40 degrees. I have a Volvo wagon that has a similar issue with an air pump for preheating for the turbo when it is a cold day. After a short warm up it also goes away. The 911 is slated to go in this month for state inspection so the issue should be easy to replicate unless PA has a heat wave in November.
1984 911 M491
2014 Accord
Old 11-04-2004, 07:16 AM
Screaming heater :O
Was this issue resolved? Had the same issue in both an 84, and now in an 86 3.2 coupe. Squalling noise when heater is turned on (sounds like a bearing or motor). Goes away once warmed up--side note, when I turn it up all the way, it goes away faster (thus bearing/motor diagnosis)--sometimes it decides to come on/open up on it's own, bringing heat into the car. It is on the drivers side, and it's precisely what was described in this original post. I know someone has to know what this is. Could use some guidance. Thanks!
Old 02-08-2011, 01:51 PM
gtc gtc is offline
abides.
gtc's Avatar
The original problem sounds like a bad ambient air valve. (on cold days they sound like a moose or chewbacca is in the airbox)
Your problem sounds like a heater blower motor with shot bearings.
Graham
1984 Carrera Targa
Old 02-08-2011, 02:30 PM
i have the same issue but don't need to use the heater as much. are the bearings easy to replace or am i looking at getting a new heater. i assume an used one would eventually do the same thing.
ken
87 targa
Old 02-08-2011, 02:40 PM
Goldfinger
Mattcamp's Avatar
Originally Posted by gtc View Post
the original problem sounds like a bad ambient air valve. (on cold days they sound like a moose or chewbacca is in the airbox)
your problem sounds like a heater blower motor with shot bearings.
+1
1984-Carrera (pewter metallic)
Old 02-08-2011, 03:02 PM
That, or both! Ugh. Thanks for responding.
Old 02-08-2011, 03:41 PM
It seems like these threads pop up every time cold weather is around.
I changed my ambient air valve last year and now have no noise when it's cold.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 02-08-2011, 03:44 PM
Here is an old thread with pics of how to do this for those who want to know.
engine bay buzzing noise
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 02-08-2011, 03:58 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1
'85 Carrera Targa
PCA/POC
Old 02-08-2011, 07:29 PM
mine sounds like a dying duck going "waaaaaaackkkk!!!"
Old 02-08-2011, 07:33 PM
