headlights
I noticed the orig factory headlights are not that bright on my 83 911. What is the popular upgrade/replacement? Looking for winter projects on the car since it is colder than f*** outside
Ambitious Outsider
Kramer, replace the bulbs. You can buy a nice set of PIAA H4 Xtreme White Plus.
the bulbs in the picture are not H4's but should give you an idea. While your at it, you can also pick up new rubber head light seals from pelican. Also do a search on HID... There is a really good thread on projection lighting.
1988 3.2 Cab 2005 997.1 C2S Last edited by sabeo.m; 02-10-2011 at 10:22 PM.. |
You might find the reflective coating on your lights has faded. Not sure exactly which lights they are but on my H4's I took apart and painted with a 'chrome' finish. There may be some comments about how the authorities view this but I can tell you that mine are alot brighter now. The dim yellow glow is now a bright white, similar to my everyday car, a 2010 VW.
If they are H4's you can get the reflectors replated but you can also buy replacements that would be more cost effective.
My first love - 1993 964 C2 Manual Coupe My second love - 2021 Macan GTS |
Member 911 Anonymous
1st what kind of lights do you have?
If H1's: Relays and Sylvania Silver Star's are the 2nd highest Lumens output on the market
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
What you do, depends on what you have currently installed.
DOT Sealed beams? Install H-4's (either the Hella drop ins Pelican Parts - Product Information: 70476-M44 or Bosch Euro Pelican Parts - Product Information: 0-301-800-103-M14) If you have H-4's already, hotter bulbs. Be sure you install a relay to prolonghte life of your flasher stalk. http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=JWST-911-HLPR&catalog_description=Headlight%20Relay%20Kit%2C%20% 39%31%31%20%28%31%39%37%34%2D%38%39%29%20
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 02-10-2011 at 10:35 PM.. |
not sure what i have right now. They say Halogen across the glass on the front. Have not looked at how they even come out. Are there screws under those 2 black plugs near the bezel I presume?
Go to ebay and buy an HID bi-xenon kit. But be sure and get the one that moves the arc not the one that has a separate halogen bulb "strapped on" for high beam. The bi-xenon bulb plugs in the housing in place of the DOT halogen bulb.
The easiest upgrade is to replace these with some H-4 lights. You will need to decide if you want the euro look using the Bosch units or just go to your local Autoparts store and get the Hella units. If you go the Hella Route, get the Euro version that will be lableled "For off road use only". I have the euro Hella units wirth 55/60 watt bulbs and the improvement was stunning. The black plugs you see on your trim rings are for access to the headlamp adjusting screws. At the base of the trim ring, there should be a screw head. This is removed and the trim ring can then be removed. The headlamp is attached to the headlamp carrier by several screws which hold a metal ring that captures the lamp. If you go the Bosch Route, the entire headlamp assembly that is bolted to the fender will need to come out and be replaced by the new units. Post a picture of your headlamps (head on and include the surrounding area).
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 02-11-2011 at 12:24 PM.. Reason: typos! :mad: |
Your best alternative is a set of H4 headlights, you can then use 80/100w bulbs as long as you use a couple of headlight relays. Everything is available from our host. None of the HID setups really work.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
HID lights
I disagree with the statement that HID lights dont work. I installed a conversion kit 2 years ago and love them. I previously had 100w /80W H4 lamps. These were good but generated a LOT of heat and started to melt the plastic bulb holders. I changed to HID and found them to be exceptional, a bit of messing around to install them in a 911 compared to a conventional vehicle due to the headlights being uot on the front guards but worth the effort. No dazzling on coming traffic they use the standard front lenses and are great a massive improvement.:
can't seem to find the headlight seals on Pelican -can you send me the link please?
RETIRED
Post a pic of what you have. Don't go hog wild until we ID what you have.
Relays and/or bulb replacement may be all you need.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Please post a picture so we can help you id the necessary corrective actions.
You probably do not need new seals as the ones that are there will most likely be ok. If needed, you can find new ones here: Pelican Parts - Product Information: 911-631-115-02-M136
The H4's, (in either flavour, Euro or flat) are a huge improvement over the sealed beams, even with the bulbs that are included in the box. When I first bought my car, it had normal sealed beams which were in no way, adequate. I installed the Bosch "Euro" H4's with the bulbs that were in the box I (believe 55W) and for me, they're perfectly fine and a huge improvement. Cheers
My 82SC
SEALED BEAM-Sylvania H6024XV XtraVision 65-Watt High Performance Halogen Headlight/Autozone. Great light-and lasts..... Walt |
Best bulbs for H5's?
DS
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
RETIRED
I'm not convinced that high end "Designer Bulbs" are worth the price....
First order of business is to chase grounds and make them absolutely spotless with some dielectric grease added afterwards. Then make sure headlights are clean inside and out (do a search on the various methods if you're running H4's or the like that may get dirty inside). The stock coinfiguration needs relays....not just for later high-watt bulbs...so do that too to save the light stalk switch from getting bad. Then we'll go from there....
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 02-14-2011 at 04:54 AM.. |
