Starter removal on '87 911
I'm working on my '87 911 targa (G50 gearbox) and I need to remove my starter to replace/repair and I'm struggling to see how it can be done without removing the whole motor. I can get at the lower 10mm allen key bolt but the one on top appears to be out of reach. Is there a trick to doing this?
I've looked through this forum and found a 2002 post saying you could reach over the gearbox up to '86 models. Thanks Ian |
Ian,
First, you should own a shop manual, if you don't already. I have the Bentley and it is pretty detailed. It has fairly detailed description on how to do this job. OK you don't need to drop the whole engine. You only need to lower the rear mounts (by the transmission) a few inches. There are a few steps that you need to follow so not to do unintended damage to the linkages. I think there is a thread on this somewhere in the Pelican forums. I used the Bentley, and it was fine. I also replaced with a high torque starter that I purchased right here from Pelican. Rick
1987 911 Carerra Coupe 2006 VW Jetta TDI two german black beauties
a partial engine drop is required. No other way. It helps if you have a longish 10mm allen socket with a ball end, and a longish flexible handle ratchet.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thanks guys.
Just found this Starter Removal Question for '87 Carrera which gives more info. I do have the Haynes manual but it doesn't give detail on this job. The Bentley seemed a bit expensive @ €100+ on ebay |
Well worth the cost,IMO. Between the Bentley manual and Pelican, you can tackle most any job that you would care to consider.
I balked at spending the money as well but now that I have it, the manual is one of the best tools I have for the 911.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
muck-raker
iancass,
you have a PM, check your mailbox.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
The Haynes manual is good for a jack pad while you jack up your car. That is all.
6 cylinder symphony
I agree. I hate the Haynes manual. I bet it says something like this:
Remove starter. Installation is reverse of removal. And that's it. POS. Ken
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
I'm here to cause trouble
+10 on the flexible handle ratchet....
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
