super9064's Avatar
Any thing good about Ethanol?
I run a 3.2 with PMOs in my early 911. Has anyone had first hand experience with Ethanol and new PMOs, are they designed to work with E10-E15.
What would we have to modify on early cars to avoid fuel related problems?
My understanding is ethanol based fuel has a higher octane rating, can we build higher compression motors with out the need for twin plugging?
Old 02-06-2011, 12:48 PM
boxster03's Avatar
I say only 2 good things.
1) Corn farmers making out like bandits
2) keeps the moisture in your tank undercontrol in the winter
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 02-06-2011, 01:24 PM
AutoBahned
RWebb's Avatar
best thing is to contact Richard Parr
also use the new Goodyear or other brand of fuel hose rated for EtOH
it will help clean the motor a bit - I'd avoid anything over E10
you could also talk to the drag racer community...
Old 02-06-2011, 01:56 PM
VFR750's Avatar
You'll need larger jets to offset the lower energy content of e10. E15 will require even bigger jets. I hear cold starting will be harder with e15. I run e10 now, CT...
Old 02-06-2011, 02:00 PM
Senior Advisor
James Brown's Avatar
This is the best use for corn ethanol.
08 Cayenne Turbo
Old 02-06-2011, 02:06 PM
