Scotiagreg
SWB brakes.... stupid idea ??
I am building a 68 SWB 911 from an 912 tub that I bought minus driveline. I am trying to decide what route to go with the rear brakes. I have parts from both a 72 and a 73 parts car including front S calipers which I will be using. What is the best and most reasonable option for the rears?
1. Is the adapter piece I have seen on old posts still available? Could I use the 72 set up with an adapter ? 2. Will the original (912) calipers with spacers and 944 rotors match the front S's? 3. Stupid idea. Has anyone shortened the radius arms from a later car and gone that route? Then you would not need adapters to go with the 72 set up. I haven't seen any write ups on #3 so I assume there may be a good reason it is not practicle. Is there a standard route to go? Thanks, Greg
1963 356B, 1968 hotrod 912/6 1985 Carrera, 1992 Carrera 2 Targa 2005 Boxster S, 2017 Macan S |
Max Sluiter
I suggest asking here: Early 911S Registry
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
The steel banana arms can be cut and rewelded, but most people just modify SWB arms to accept a different caliper and a vented disc.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I am in the same boat, this is what i know of as options:
the adaptors i have not seen in awhile, not sure you can find those. there was someone on early S selling an alternative caliper that uses the 944 rotor. the non-vented rear calipers had a smaller diameter piston than the vented S calipers so the bias would be off a little if you upgrade just the fronts. TRE does make an adaptor for swb to use boxster calipers and 944 rotors. shortening the lwb arms would be a lot of work, i have not seen anyone try it. the stock rear non-vented brakes are not too bad - many racers use the stock solid rotors and just use better pads and fluid. i haven't decided what i'm going to do, i might try and make an adaptor so i can use wilwood calipers.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
