Repair early door arm
I have an early (72) interior door arm where the upper flat part of the rubber has pulled away from the metal frame. If it hadn't warped so badly I would have re-glued with contact cement, but I have my doubts about the contact cement being strong enough.
Wondering if 3M or Permatex super weatherstrip adhesive might do a better job?
Anyone with some thoughts, experience or a better suggestion?
Thanks!
Rob
65 356SC Cab - 70 T Sunroof Coupe - 82 SC Targa - 86 Coupe - 87 Targa - all sold years ago
89 944S2 Daily Driver-Sold because...still thinking why.
73.5CIS Targa Shed Find -On the Road Again
Old 01-12-2011, 09:34 AM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Bump
Old 01-13-2011, 10:24 AM
ratpiper71T's Avatar
I hope you get your answer as I haven't figured out what I'm going to do to repair this either. So far my idea has been (I haven't done this yet) to cut some slits across the peice and use a heat gun to reform it and glue with an upholstry adhesive, then fill cracks with expanding foam or the goo from one of those dash repair kits, trim and sand, then plastic body filler, sand, then recover with vinyl. I'm not sure how these will weather over time?
Whaddaya think?
Mama lock your daughters up that wild bunch is back in town!...And them little girls get frisky when they hear that race-car sound!
Old 01-13-2011, 10:52 AM
boba's Avatar
Not sure what might work but you might contact some of the folks who re-do dash pads. If you search you should come up with a few names.
An other option would be to convert over to RS style door cards. This may be cheaper than repairing your existing part.
Old 01-13-2011, 02:24 PM
Buy a pre-owned arm rest in better shape. They show up quite often. Might be less expensive than repairing yours.
Sherwood
Old 01-13-2011, 05:07 PM
al lkosmal's Avatar
warpage
Mine weren't warped as badly as yours, but I used 3M Weatherstrip adhesive (elephant snot). I applied the adhesive and then heated up the armrest with a hair drier and using a flat board and clamps, i clamped it flat and left it to dry, overnight. It really worked well for me.
regards,
Al
PS: I recovered the door pockets, as well.
RGruppe #669
http://www.x-faktory.com/
Old 02-18-2011, 08:45 AM
