-   -   While the 915 is out. What else should I do (http://forums.pelicanparts.com/porsche-911-technical-forum/591035-while-915-out-what-else-should-i-do.html)
JJ 911SC 02-11-2011 04:49 AM
Now that the cleaning phase is completed, while I will not be going in... beside replacing the Guide Tube O ring and Shaft Sealing Ring, anything else I should consider.
JJ
Before:
http://forums.pelicanparts.com/uploa...1294573347.jpg
http://forums.pelicanparts.com/uploa...1294573118.jpg
5 Hrs, 2 Toothbrushes, a roll of paper towel & 4 rags later:
http://forums.pelicanparts.com/uploa...1294573624.jpg
http://forums.pelicanparts.com/uploa...1294572870.jpg
http://forums.pelicanparts.com/uploa...1294574235.jpg
http://forums.pelicanparts.com/uploa...1294574348.jpg
Kidasters 02-11-2011 05:20 AM
Transmission mounts - I'd change them as well.
jmccam 02-11-2011 05:22 AM
Very nice.
don gilbert 02-11-2011 06:07 AM
I would at least put a new throwout bearing and pilot bearing in. Cheap insurance. Inspect the arm really good for cracks or warpage. The plastic bushings for the pivot are easly replace to.
BK911 02-11-2011 06:08 AM
Throttle linkage thingy bushings?? PP has brass ones.
I really like the picture where half is clean. Shows a dramatic difference.
What did you use as a cleaner?
tobluforu 02-11-2011 06:15 AM
Is the motor out as well, if so what year? I'm amazed at the difference-looks great!
JeremyD 02-11-2011 06:30 AM
+1
I'd also look at either replace the trailing arm bushings or installing monoballs.
Drisump 02-11-2011 06:31 AM
JJ you're going to have to install a mirror floor in the garage....WOW.... Q-tips?
JJ 911SC 02-11-2011 07:46 AM
Thanks for all suggestion and comments.
No, the mirror is staying above the bed:D:):D
The engine and transmission are 1986
The transmission and engine mount have been change.
The clutch cable is being change
Porsche Short Shift kit going in
All bushing being change
New clutch kit going in along with new throwout bearing and pilot bearing in
Probably will not meet my target date of 1st of April to be on the road :D:(:D
The cleaner is Facto AT-30 from http:www.swishclean.com/clean-itcenters.htm?ECINFO=//SWISHLOCATIONS (Canada/US/Europe)
Less than $5 a Liter in a 20 liter pale.
http://forums.pelicanparts.com/uploa...1296959633.jpg
http://forums.pelicanparts.com/uploa...1296959707.jpg[/QUOTE]
Bob Kontak 02-11-2011 08:47 AM
Re-facing flywheel and replacing the rear crankshaft seal is an option.
don gilbert 02-12-2011 09:03 AM
you could also put this brand new never been used PMS forged flywheel in to. For real cheap. If you were so inclined.http://forums.pelicanparts.com/uploa...1297530187.jpg
JJ 911SC 02-12-2011 09:12 AM
[QUOTE=don gilbert;5842516]you could also put this brand new never been used PMS forged flywheel in to. For real cheap. If you were so inclined./QUOTE]
PM on your way :)
rusnak 02-12-2011 09:48 AM
+1. I would at mimimum take the pivot shaft out, and grease it with good grease. There is a very special grease for the clutch splines. The splined shaft section must be clean, and make sure the two slide smoothly.
don gilbert 02-13-2011 04:27 AM
got your pm jj, and noticed in your garage that "the babe" has a 3.2 . this flywheel is for a 3.0 engine. You need to find out if it will work on the 3.2. it might, i just dont know.
JJ 911SC 02-13-2011 05:04 AM
OK
I'm taking advise on this one but... I'm afraid that I know the answer.
While the clutch brige the 83/86 year, the flywheel seem to be more specific;
911 Flywheel (1974-77), New
Brand: OEM [More Info]
911 Flywheel (1978-79), New
911 Flywheel (1980-83), New
911 Flywheel (1984-86), New
911 Flywheel (1987-89), New
I hate passing a good deal...
don gilbert 02-13-2011 08:22 AM
oh well. good luck on the engine, looks good.
