83 911 Production Cab #10
While the 915 is out. What else should I do
Now that the cleaning phase is completed, while I will not be going in... beside replacing the Guide Tube O ring and Shaft Sealing Ring, anything else I should consider.
Thanks JJ Before: ![]() ![]() 5 Hrs, 2 Toothbrushes, a roll of paper towel & 4 rags later: ![]() ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
6 cylinder symphony
Transmission mounts - I'd change them as well.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
Very nice.
1983 Porsche 911 SC Coupe "We will either find a way, or make one" - Hannibal |
grateful user
I would at least put a new throwout bearing and pilot bearing in. Cheap insurance. Inspect the arm really good for cracks or warpage. The plastic bushings for the pivot are easly replace to.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Home of the Whopper
Throttle linkage thingy bushings?? PP has brass ones.
I really like the picture where half is clean. Shows a dramatic difference. What did you use as a cleaner?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Is the motor out as well, if so what year? I'm amazed at the difference-looks great!
72 911 Although it is done at the moment, it will never be finished. |
MBruns for President
I'd also look at either replace the trailing arm bushings or installing monoballs.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
JJ you're going to have to install a mirror floor in the garage....WOW.... Q-tips?
Thanks for all suggestion and comments.
No, the mirror is staying above the bed ![]() ![]() ![]() The engine and transmission are 1986 The transmission and engine mount have been change. The clutch cable is being change Porsche Short Shift kit going in All bushing being change New clutch kit going in along with new throwout bearing and pilot bearing in Probably will not meet my target date of 1st of April to be on the road ![]() ![]() ![]() The cleaner is Facto AT-30 from http:www.swishclean.com/clean-itcenters.htm?ECINFO=//SWISHLOCATIONS (Canada/US/Europe) Less than $5 a Liter in a 20 liter pale. ![]() [/QUOTE]
Fleabit peanut monkey
Re-facing flywheel and replacing the rear crankshaft seal is an option.
grateful user
you could also put this brand new never been used PMS forged flywheel in to. For real cheap. If you were so inclined.
[QUOTE=don gilbert;5842516]you could also put this brand new never been used PMS forged flywheel in to. For real cheap. If you were so inclined./QUOTE]
PM on your way
+1. I would at mimimum take the pivot shaft out, and grease it with good grease. There is a very special grease for the clutch splines. The splined shaft section must be clean, and make sure the two slide smoothly.
grateful user
got your pm jj, and noticed in your garage that "the babe" has a 3.2 . this flywheel is for a 3.0 engine. You need to find out if it will work on the 3.2. it might, i just dont know.
OK
I'm taking advise on this one but... I'm afraid that I know the answer. While the clutch brige the 83/86 year, the flywheel seem to be more specific; 911 Flywheel (1974-77), New Brand: OEM [More Info] 911 Flywheel (1978-79), New Brand: OEM [More Info] 911 Flywheel (1980-83), New Brand: OEM [More Info] 911 Flywheel (1984-86), New Brand: OEM [More Info] 911 Flywheel (1987-89), New Brand: OEM [More Info] I hate passing a good deal...
grateful user
oh well. good luck on the engine, looks good.
