5String
Timing Help, Please
I just set the timing on my car, an '82 SC. Thought I'd better - it's very hot and dry here today and I noticed that on full throttle, it's pinging like an SOB.
So I did the job, working only to setting the advance at idle. Found it considerably advance. I dialed it back.
But should the vacuum lines remaining connected when I check idle setting? Or should they be disconnected?
I'd be very grateful for the group's wisdom. I'd like to get this right. (Did a quick search, did not find the answer to be immediatly evident.)
Thanks - Jon
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 02-12-2011, 05:12 PM
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 02-12-2011, 05:17 PM
Senior Advisor
James Brown's Avatar
^^^^^^See above and copy it ^^^^^put the copied page in your BENTLEY 911SC REPAIR MANUAL.
08 Cayenne Turbo
Old 02-12-2011, 05:19 PM
5String
Thanks very much, gents. I presume that means BOTH vacuum lines disconnected.
5String
The Northwest Files
Old 02-12-2011, 05:26 PM
Senior Advisor
yes,
08 Cayenne Turbo
Old 02-12-2011, 05:27 PM
5String
OK, redid the job, the settings were correct in the first place, which means that with the vacuum lines both disconnected and connected, the timing marks line up right where they are supposed to/right where they did before I started fiddling around.
Which leaves this question: Why is it pinging so badly? It's got to be running way lean, I figure.
Thoughts?
5String
The Northwest Files
Old 02-12-2011, 05:51 PM
Thoughts?
Several reasons are possible and those include:
1) Insufficient octane: mis-fueling is not uncommon and this occurs when a gas station's tanks are mis-fueled with the wrong product. You should be using 91 octane fuel.
2) Sticking advance mechanism resulting in too much mid-range advance.
3) Incorrect fuel mixture.
4) Incorrect spark plug heat range.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-12-2011, 06:20 PM
5String
Thanks, Steve. I'll check on all.
5String
The Northwest Files
Old 02-12-2011, 08:37 PM
