-   -   Release fork - replace? (http://forums.pelicanparts.com/porsche-911-technical-forum/591295-release-fork-replace.html)
BlueWing 02-12-2011 04:00 PM
Running over budget (how can that happen!) but how important is it to replace the release fork on my 70SC? I'm swapping out a bad sycro'ed tranny for a spare. If the spare is good it might stay a few years as I have not put too many miles on annually but if better to drive with the spare that might change.
Goal is to rebuild and reimstall the original but right now I don't know if it will be at a leasure or panic pace. With all the other preventative maintenance going on is a 130.00 saved worth it?
Thanks for any input.
Terry
JJ 911SC 02-12-2011 04:14 PM
Terry
Originally Posted by BlueWing (Post 5843040)
Running over budget... This is the first time I ever heard of this happening!
... Goal is to rebuild and reimstall the original but right now I don't know if it will be at a leasure or panic pace. Had the same dream... Start to panic now!
... Is a 130.00 saved worth it? At this time its too late to try save money :D:):D
Have Fun
john walker's workshop 02-12-2011 05:10 PM
some crack, some don't. more likely on an old clutch with a thin disc, because they are harder to pull.
fanaudical 02-12-2011 05:31 PM
I'd replace - fairly cheap insurance. The fork (which was broken when I disassembled my 75) design appears to be a little light to me.
BlueWing 02-13-2011 08:48 AM
I guess the right way is to replace it.
JJ I've been following your thread - funny but you are right
JW your track record speaks for it self I'd rather learn from wisdom than being dum
fanaudical - Insurace is the second highest expense in my life so why crap shoot on my time/labor.
Thanks guys just trying to talk myself into saving somewhere. Exterior non criticle bolt ons are a better savings gamble.
Terry
LUFTMAN 02-13-2011 10:13 AM
i have many good used 915 forks cheap
JJ 911SC 02-13-2011 02:17 PM
JJ I've been following your thread - funny but you are right...
Terry
Terry
Glad you see the humor in this.
My adventure started last year with, I'll get the lift and save a lot of money...
I'll drop the engine to clean, stop all leaks and do the valve Adjustment job that should be rather cheap!!!
Might as well put some SSIs and a MK muffler since the other one are working perfectly... Lets put a Short Shift Kit so I get a better 0-60 time... Well a Super Clutch would complete the job... Why spend money re-facing the flywheel...
I hope it will be over soon, I'm already in the 2012/13 budget :D:eek::confused::):confused::eek::D
gduke2010 02-13-2011 03:53 PM
Yes, replace. when I had a new clutch and flyweel installed, the mech. taliked me out of replacing the fork and within a couple mounths it broke. the clutch and flywheel had to be replaced again.
It's real cheap insurance.
Gary
