Doug Harris (guest)
Guest
Posts: n/a
I have a 1971-911 have installed a newer alternator with a built in regulator, the system is charging because I have a volt meter mounted in the car but the alternator light stays on. I know its something simple, any suggestions?
Doug
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 911 Alternator and Fan Replacement & Upgrade
Old 02-12-2011, 10:52 PM
Author of "101 Projects"
Wayne 962's Avatar
I just ran into this issue the other day with another customer. I have a PDF of a Porsche Technical bulletin that talks about putting in a higher wattage bulb to assist with getting the lamp to go out. I have the link here: http://www.pelicanparts.com/techarticles/911_alt_replace/Alternator.pdf
- Wayne
RETIRED
Joe Bob's Avatar
I'm not above confirming the reading of a 40 year old dash gauge. The light is part of the charging cicuit.
2012 ML350 3.0 Turbo Diesel
Old 02-12-2011, 11:06 PM
kodioneill's Avatar
You need a higher resistance in the bulb circuit. You can add a resistor across the bulb contacts to achieve this. Use the search function you will find the value of the resistance needed. I think you need 84 OHMS at 5 watts.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-13-2011, 06:22 AM
i have the plug in resistor kit ready to plug on to your altenator charge lite as per factory tech. update. $20.00 shipped
Old 02-13-2011, 10:27 AM
