wheels options for 1970 t
Doing some refurbishment and light mods to a new to me irish green 1970 911 t coupe, pretty stock as is. Has steel wheels (which I'll keep) but I want rsr look fuchs. Is 15x6 all around the largest I can go or will 15x7 fit in the rear? Don't want to roll fenders. Braid has a 15x6 and 7 rsr finish but its not "deep dish". I'd also like to go with a beefy sidewall tire kinda like Magus Walker's 277 car before he switched to the urban outlaw wheels. And which tires are a whole separate question.. Thanks
Old 06-09-2017, 07:14 AM
Flojo's Avatar
front 6x15
rear max 7x15
because: best look.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 06-09-2017, 07:20 AM
3 restos WIP = psycho
kenikh's Avatar
7s all around on a narrow body car fits fine and looks *****in. You can fit anything from 185s to 205s.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-09-2017, 07:34 AM
Bill Verburg's Avatar
Easiest no hassle fit is the oe sizes 6ET36 x15 w/ 185/70 tires
7RET23.3 can be fitted at either end, not much issue w/ normal tires sizes in front but you have to watch the height vs width of the tire in back.
At normal ride height w/ standard suspension a 215/60 on 7ET23.3 will rub at full compression, the rub is well up into the rear fender not at the lip. This tells me that it is a tire height problem. 215/60 x15 is ~25" tall & has a s/w of ~8.7"
a 205/50x15 @~23.1" OD & s/w 8.5" would be no problem , but the speedo would be way off if that's a concern.
a 225/50 x15 @23.8"OD & s/w 9.1 would be ok, I see lots of these at the track
Bill Verburg
Old 06-09-2017, 08:06 AM
Administrator
Luccia at Pelican Parts's Avatar
Also, maybe check out our wheel fitment guide for additional input on sizing: Wheel Fitment and Spacing Guide - Pelican Parts. Be sure to share pictures with us once you get it figured out!
Old 06-09-2017, 10:09 AM
cycling has-been
bkreigsr's Avatar
Some of the earlier cars (my '73) can vary side-to-side clearance as much as 3-4mm.
So if the 205's on 15x7's fit nicely on the left - you may still need a tweak on the right.
I trimmed about 1/8" off the actual lip with a Dremel.
YMMV
Bill K
Old 06-09-2017, 10:33 AM
So front 15x6 +35 with 205/55 is a definite fit. 15x7 might fit too with same tire.
Would rear 15x7 +48 7R with 225/50 fit?
Bill what is that s/w measurement you mentioned?
Don't really mind speedo being off.
Old 06-09-2017, 11:22 AM
cycling has-been
bkreigsr's Avatar
Simply stated, all Porsches are not created equal.
Right side tolerance (from centerline) is often different then left side.
Old 06-09-2017, 03:34 PM
kenikh's Avatar
^^^SO TRUE^^^ I've seen 3/4" factory variance from side to side.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-09-2017, 03:36 PM
given tire limitations on 15" wheels you might want to consider going with 16" fuchs, as the 16" size opens up a LOT more options.
Old 06-09-2017, 04:01 PM
Fuchs 6 have ET36
15x6 +36 with 205/55 is a definite fit. 15x7 might fit too with same tire.
yes and yes
s/w - section width
205/55 is 23.9" OD, 8.4" s/w, 7" t/w
Bill Verburg
Old 06-09-2017, 04:03 PM
In some sizes, yes, but no in all
It's surprising but most sizes of hp tires are limited to only a few choices no matter 15, 16, 17 or 18, You get more choice when you expand to a/s or less performance oriented tires
Bill Verburg
Old 06-09-2017, 04:07 PM
kenikh's Avatar
And 16s look like ass on an early narrow body car.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-09-2017, 04:19 PM
Sporttracguy's Avatar
[IMG] photo 16X7_zpsf9genddz.jpg[/IMG]
16X7"
Old 06-09-2017, 05:15 PM
Been here a while
I have a full set of 15x7's that were on my 72t when I bought it, with new tires 3 years ago. Search my user name for an old ad that shows then. I'm in NJ so it's an easy pickup.
looking for 1972 911t motor XR584, S/N 6121622
Old 06-09-2017, 05:22 PM
HarryD's Avatar
Really?
Looks ok to me.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-09-2017, 05:44 PM
kenikh's Avatar
To each their own
- 1969 911S
- 1980 911SC Targa
- 1979 930
cycling has-been
bkreigsr's Avatar
Originally Posted by Bill Verburg View Post
s/w - section width
Oh - the aspect ratio !!
Bill K
Old 06-09-2017, 07:47 PM
SWS911's Avatar
I would go with the fuchs reps in a deep 6 and 7R x 15 from gearheadgreg and it would look sooo right without spending a crap load of $$$ on the originals. These style wheels were on '70 - '71 P-cars and would look period correct.
Old 06-09-2017, 08:07 PM
cycling has-been
bkreigsr's Avatar
16x6's on a narrow body.....
.........depends on how they are painted.
Bill K
