Engine decode
Anyone who can help me decode this engine ??
911/07 9011061015R Casting: 6117394 Thanks...... SmileWavy |
911/07 70/71 2.2 911T engine 84x66, 2195cc I 46, E 40 I 32, E 32 8.6:1 125 hp @8500rpm 130 lb/ft @ 4200rpm
1970-71 2.2 for USA 125 hp 130lb/ft torque. with Zenith 40 carbs. :D What's up JB ?
Thank you guys. That as quick !!
I bought the car/motor as a 2.7, but seller said that the case have been changed at some point, and all other parts from the 2.7 bolted into it. Is it possible to interchange the cylinders etc. on these, and make a 2.2 a 2.7 ??? The injection etc. from the 2.7 is all there....... |
Typically not done due to expensive machine work and (usually) better alternatives. The cylinder spigots would have been enlarged to fit the 90 mm bore cylinders. There would be needed hand-work inside the case to clear the rods and piston skirts. Check under the engine for iron (2.2T) cylinders or aluminum (2.7) cylinders. Best, Grady |
Thank You very much for the explanation, Grady.
| All times are GMT -8. The time now is 09:07 AM. |
