Engine decode
Anyone who can help me decode this engine ??
911/07 9011061015R Casting: 6117394 Thanks......
Regards, Heine Hansen http://www.carnut.dk/us - http://www.policecar.dk http://www.youtube.com/user/danishcarnut 1963 Mercury Marauder - 1974 Porsche 911 2.7 1961 Porsche Speedster "Replica" - 1971 Plymouth Fury - Walnut Creek P.D. |
RETIRED
911/07 70/71 2.2 911T engine 84x66, 2195cc I 46, E 40 I 32, E 32 8.6:1 125 hp @8500rpm 130 lb/ft @ 4200rpm
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Canyon Runner
1970-71 2.2 for USA 125 hp 130lb/ft torque. with Zenith 40 carbs.
What's up JB ?
Thank you guys. That as quick !!
I bought the car/motor as a 2.7, but seller said that the case have been changed at some point, and all other parts from the 2.7 bolted into it. Is it possible to interchange the cylinders etc. on these, and make a 2.2 a 2.7 ??? The injection etc. from the 2.7 is all there.......
RETIRED
Typically not done due to expensive machine work and (usually) better alternatives. The cylinder spigots would have been enlarged to fit the 90 mm bore cylinders. There would be needed hand-work inside the case to clear the rods and piston skirts. Check under the engine for iron (2.2T) cylinders or aluminum (2.7) cylinders. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thank You very much for the explanation, Grady.
