Recreational Mechanic
Help with Dwell Meter CIS Mixture Adjustment
I have the Actron analog dwell meter hooked up on my 82 911SC, trying to adjust the mixture properly. I have a brand new O2 sensor installed in SSI's (no cat). What should I be seeing???
The needle fluctuates between 5 and 10 degrees on the 8-cyl scale for dwell. According to what I have read here it should be more like 20-25 degrees on the 8-cyl scale, however no matter what I do w/ the mixture screw it does not seem to change much. Am I not turning the mixture screw enough? I am turning it back and forth (clockwise for rich/counter for lean) about one full turn either direction and the engine speed changes, but the fluctation range on the dwell meter seems to change very little. Any help is appreciated.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
What does the dwell meter have to do with the mixture? Dont you need a exhaust gas analyzer to measure CO. Good luck
On CIS-Lambda cars you hook a dwell meter to the test port and use the duty cycle of the O2 sensor to set the mixture. CO can be used if the car has no O2 sensor (ie: early CIS w/o Lambda or Euro models).
Mike Holbrook
This may be one of the first tips I have heard that might make a later SC in some way easier to tune than the earlier ones. I do know that messing around randomly with that allen wrench can really mess things up. Especially if the car has a couple bad or weak plug wires and one or two plugged or partially plugged injectors and has been sitting for 8 or 9 months not running. Ask me how I know.....
Mike Holbrook Meridian, ID 1979 911SC Targa |
SC Ray
Hi Nick,
I have been down this road. I bought the damn dwell meter and did the whole thing. Got the needle to swing. After that, my gas mileage went down to 11 and 15 respectively. So, I brought it to my resident pro, Abacus Racing, and they informed me I had messed up my mixture to the point that the lambda could not compensate. So, they adjusted it using a exhaust gas analyzer. Now all is well. Just admitting my failures to try and prevent you from doing the same ![]() Ray |
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code Last edited by Neel; 02-15-2011 at 08:02 PM.. |
True. At least I know that the O2 sensor is working b/c the Dwell meter was cycling from 5-10 degrees very regularly and I can hear the Frequency valve running. The car runs great, I'll check it again after I pull the engine and button up all possible vacuum leakes etc (when I get around to it....). I know CIS can be very sensitive to lots of minor issues that culminate into driveability problems, mine have just not become major enough yet to effect how the car runs.
Fleabit peanut monkey
Are you dropping he 3mm wrench down the hole or turning the air bypass screw? The air bypass screw makes the engine run faster or slower without adjusting the af ratio.
My $.02 as always...
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Nick,
It sounds like the meter or the hook up is not right. The needle should change its range with as little as 1/8 or 1/4 turn of the mixture screw. I would try a different meter.
Paul |
