-   -   If points gap is correct, should dwell also be? (http://forums.pelicanparts.com/porsche-911-technical-forum/592448-if-points-gap-correct-should-dwell-also.html)
jwakil 02-18-2011 07:17 AM
I'm trying to adjust my distributor with points. If I get the gap correct, does that imply that the dwell angle should be fine? I'm trying to decide if I need a separate dwell meter.
HarryD 02-18-2011 07:24 AM
If you get the gap correct, the dwell "should" be within range. The dwell meter will serve to fine tune the setting.
Superman 02-18-2011 08:02 AM
Harry is correct. However, no matter how close you think the gap is, the dwell angle will almost certainly be incorrect. A dwell meter will tell you how close you got it when you set the point gap. Also.....dwell meters can be had for peanuts. Thrift stores, pawn shops, garage sales, etc. Better yet, do yourself a big favor and upgrade to an electronic ignition trigger.
Bill Verburg 02-18-2011 08:04 AM
point gap determines dwell, the wider the gap the lower the dwell.
The more precise measure is dwell.
Set the gap w/ feelers then zero it in w/ dwell.
since the primary issue w/ points as implemented in a Porsche CDI system is rubbing block wear and the resulting decrease in point gap over time, it's best to set up the gap on the high side, which is on the low side for a dwell measurement
911pcars 02-18-2011 01:30 PM
To add to Bill's response: Every 1 degree of dwell change also changes the ignition timing by the same amount. Thus, as the rubbing block wears, the point gap becomes smaller and the ignition retards (e.g. 5ºBTDC > 4ºBTDC).
Sherwood
rattlsnak 02-18-2011 08:01 PM
yes, and dwell affects timing, but timing does not affect dwell...
dan88911 02-19-2011 11:28 PM
Don't mean to high jack. However, what is this electronic ignition trigger you speak of ? :)
HarryD 02-20-2011 11:50 AM
Good question. I presume we mean someting like Pertronix (Pelican Parts.com - Pertronix Ignitor) or other electrical item to replace the points with an electronic triggering device.
dan88911 02-20-2011 06:29 PM
Thanks HarryD. I remember something like this in the 70's for muscle cars.
Joe Bob 02-20-2011 11:15 PM
Pertronix while a good idea, are failure prone, hence the recommendation to carry points with you on the road.....
