If points gap is correct, should dwell also be?
I'm trying to adjust my distributor with points. If I get the gap correct, does that imply that the dwell angle should be fine? I'm trying to decide if I need a separate dwell meter.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
If you get the gap correct, the dwell "should" be within range. The dwell meter will serve to fine tune the setting.
Senior Member
Harry is correct. However, no matter how close you think the gap is, the dwell angle will almost certainly be incorrect. A dwell meter will tell you how close you got it when you set the point gap. Also.....dwell meters can be had for peanuts. Thrift stores, pawn shops, garage sales, etc. Better yet, do yourself a big favor and upgrade to an electronic ignition trigger.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
The more precise measure is dwell. Set the gap w/ feelers then zero it in w/ dwell. since the primary issue w/ points as implemented in a Porsche CDI system is rubbing block wear and the resulting decrease in point gap over time, it's best to set up the gap on the high side, which is on the low side for a dwell measurement
Sherwood |
Insert Tag Line HERE.....
yes, and dwell affects timing, but timing does not affect dwell...
Thanks HarryD. I remember something like this in the 70's for muscle cars.
RETIRED
Pertronix while a good idea, are failure prone, hence the recommendation to carry points with you on the road.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
