Metal/rubber sealing washers
Looking for the metal/rubber sealing washers for the nuts for crankcase halfs.
Can't seem to locate them does anyone have a link to where I can source them...
Thanks.
[IMG][/IMG]
Old 02-14-2011, 12:30 PM
If these are for the through bolts, you need the o-rings and the washers that fit around them. Our host has the O-rings: 999-701-006-40-M213. Get the green ones and stay away from the blue ones as they are not that durable.
If you have the through bolts, it's hard to imagine you don't have the necessary washers. At any rate, our host also has these: 901-101-161-01-OEM. You may also try posting a WTB in the classifieds for these.
Dave
Dave
'75 911s Coupe
Old 02-14-2011, 12:51 PM
I updated the post with the picture of the washer.
Not sure about the o-rings are they an internal seal between the halfs?
Old 02-18-2011, 05:21 AM
What are you building, neither of those are 911 build parts.
Bruce
Old 02-18-2011, 06:16 AM
Here is a link for them
McMaster-Carr
Old 02-18-2011, 01:33 PM
prschmn's Avatar
If your talking about the 8mm bolts around the case you dont need sealing washers
as long as it's properly sealed with anerobic. Porsche to my knowledge never used
"dowty" seals which is what your picture is of.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 02-18-2011, 03:38 PM
