-   -   I Have A Clock Issue (http://forums.pelicanparts.com/porsche-911-technical-forum/592797-i-have-clock-issue.html)
Helios59 02-20-2011 07:51 AM
If I don't drive the car for more than a day, the clock stops.
Then I'll re-set it, drive the car and the clock will run just fine...until it stops after I park the car and leave it for awhile.
What's happening here?
Joe Bob 02-20-2011 08:09 AM
Test the power lead. Likely it loses 12v when the ignition switch is off. Do you have a radio with presets?
si Banker 02-20-2011 11:07 AM
Clock
I got tired of it not keeping time I replaced it with a volt meter so I could keep track of the charging system.
It saved e from having a voltage regulator break down while on a trip. I was able to see that the engine was over charging, 17.5 volts. I put the head lights on along with the rear window defogger and was able to bring it down to 14 volts.
IMO the gage is worth more that a clock.
BlkBird 02-20-2011 12:37 PM
Remove clock. Replace with vacuum operated boost guage. Smile.
