Helios59's Avatar
I Have A Clock Issue
If I don't drive the car for more than a day, the clock stops.
Then I'll re-set it, drive the car and the clock will run just fine...until it stops after I park the car and leave it for awhile.
What's happening here?
Ray
1986 Turbo-Look Cab
White Gold/Burgundy
Old 02-20-2011, 08:51 AM
RETIRED
Joe Bob's Avatar
Test the power lead. Likely it loses 12v when the ignition switch is off. Do you have a radio with presets?
2012 ML350 3.0 Turbo Diesel
Old 02-20-2011, 09:09 AM
si Banker's Avatar
Clock
I got tired of it not keeping time I replaced it with a volt meter so I could keep track of the charging system.
It saved e from having a voltage regulator break down while on a trip. I was able to see that the engine was over charging, 17.5 volts. I put the head lights on along with the rear window defogger and was able to bring it down to 14 volts.
IMO the gage is worth more that a clock.
1987 911 Coupe
Triumph Trident Track Master
History is the lie we all agree to..........
Old 02-20-2011, 12:07 PM
BlkBird's Avatar
Remove clock. Replace with vacuum operated boost guage. Smile.
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 02-20-2011, 01:37 PM
