blinker/hazard relay
With too much snow and cows fed I decided to tackle the 79 SC blinker and hazard issue. After tracing down my problem with a multimeter, I came to the conclusion that I have a bad four blade connector in which the relay fits. My old relay still works and the writton does not. I have to slightly twist the relay in the connector to get haz and blinkers to fuction. My question is do they make a new connector pig tail that I can purchase. I was not happy that the new relay did not work as is caused a lot of wasted time and effort. Secondly, I have two broken wires in the wiring loom from the connector in lug.comparment to side mirrors. I have been unable to find a loom on this sight. Do I just rerun new lines or can i replace the entire run.
Old 02-21-2011, 08:07 AM
