Non Floating Front Rotor for SC with 930's
I have decided not to do a Front Float Rotor, what are the other options to fit my SC?... am I right in thinking that 1980 on 930 will not fit SC due to wrong offset?
Thats correct; the later 930 rotors only fit a wide body car using the later (wide) 930 hubs.
FWIW, we do make a 930 flat-hat rotor assembly that we use for fitting 930 brakes on a 911. You can see them on the Brakes page of our website. These have been quite durable on all our race cars for the past 6 years. |
http://i183.photobucket.com/albums/x...ginning158.jpg vs. stock SC front rotor: http://i183.photobucket.com/albums/x...ginning143.jpg http://i183.photobucket.com/albums/x...ginning145.jpg http://i183.photobucket.com/albums/x...ginning144.jpg You will have to run a small spacer if using 16x7 "911" stamped Fuchs, or you can do what I did and use "951" stamped Fuchs from a 944 Turbo SmileWavy |
| All times are GMT -8. The time now is 06:19 AM. |
