-   -   Reusing Axle Bolts (http://forums.pelicanparts.com/porsche-911-technical-forum/593290-reusing-axle-bolts.html)
gsjohnson 02-22-2011 07:50 PM
Reusing Axle Bolts
Any opinions on reusing the axle joint bolts? Several auto manufacturers recommend replacing the axle bolts when removing them. I was just wondering if that was the case with my 68 SWB 911.
aadrew10 02-22-2011 07:52 PM
it'll probably work
RWebb 02-22-2011 07:59 PM
do you mean the CV bolts?
inspect threads & wrenching feature carefully - reuse if ok
replace Schnorr washers each time
DRACO A5OG 02-23-2011 01:09 AM
My wrench does it all the time. He only replace when they are questionable. +1 on the washers, a must.
aston@ultrasw.c 02-23-2011 06:49 AM
You can get schnorr washers from porsche but they are rather spendy
Or you can get them from McMaster Carr $11/100
McMaster-Carr
and they even come in a bag with the schnorr logo
gsjohnson 02-23-2011 08:42 AM
Yes the CV joint bolts. Thanks for the responses.
BK911 02-23-2011 08:42 AM
Aston, would you happen to have a part number? I would like to order these. Thanks, BK
cashflyer 02-23-2011 09:26 AM
Many do. Many do not.
People have differing opinions about the bolt stretch under torque, etc, and many people make their decision based on whether the car is DD or raced.
I do not reuse them.
5:04 02-23-2011 09:45 AM
Just did my rear wheel bearings and I replaced them since they have a tendency to strip (Spent 2 hours getting stripped one out) and they're cheap insurance.
rusnak 02-23-2011 10:38 AM
They're so cheap, I usually toss em. Check out your local hardware store for the bolts.
RWebb 02-23-2011 11:05 AM
local hardware store???
gtc 02-23-2011 11:08 AM
aka fastenal.com or mcmaster.com
aston@ultrasw.c 02-23-2011 11:13 AM
I thought my link would send you directly to the part but I guess not :rolleyes:
here's the # 93501A031 :D
BK911 02-23-2011 11:48 AM
Ordered. Thanks!!
aston@ultrasw.c 02-23-2011 11:51 AM
If anyone is in the Maryville area, BK911 has 100 of the bastards. ;)
Flat6pac 02-23-2011 12:00 PM
I was looking at the Bolt Depot and they are $24/100 for half shaft or pressure plate 12.9s
Bruce
rusnak 02-23-2011 01:13 PM
Yes, these are plain Grade 12.9 bolts,w automotive quality coating - nothing special.
RWebb 02-23-2011 01:35 PM
be glad you can get 12.9 at your local hardware store
be SURE they ARE 12.9 ...
rusnak 02-23-2011 01:46 PM
We have some good hardware stores here. The bolts I'm talking about are stamped 12.9. And depending on which cv boot kit you use, there are different bolt lengths too.
FIG 02-27-2011 10:36 PM
Ummm... how'd you get it out may I ask http://forums.pelicanparts.com/suppo...leys/anger.gif
It seems I have a stripped one....
