Street Roll Bar........
I would like to install a street friendly bolt in roll bar in my SC sunroof coupe. What I want would have a removeable crossbar for shoulder harness mounting. By being removeable, there would still be some access to the rear of the car for cleaning windows, etc. Any input would be very welcome!
Thanks,
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
DAS sport works well. Do you have seats w holes for the shoulder straps?
DAS works well only in the context that the whole" rear-only section" design,..... is bolt-in and removable. Once bolted in, the cross member and diagonal are part of the welded-in section of this rear-only arrangement...and makes window cleaning difficult, not easy.....
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Roll Bar
AutoPower makes one that you can remove the cross brace/diagonal
Roll hoop remains in the car. Don't suggest allowing passengers back there once removed. |
abit off center
Is it legal in a street car?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Legal or not, my conscience wouldn't be clear to (say) place kids in the back if there is a removable cross bar and such. Racing cages have energy absorbing foam attached PLUS the expectation that if you hit it with your head...it's with a helmet on. Good call.
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 02-23-2011 at 10:50 AM.. |
Had the Autopower. But took it out for exactly what wil said. I was hauling dogs though, and since I did not always want to plant a crate in the back it became a danger to them. Even a quick stop can be bad.
Tim. 1988 911 Carrera. Silver. 1973 914 Metalic Blue. 2012 Cayenne S |
The plan..........
My intentions are to redo the interior using RS carpet set, delete rear seat hardware and use a pair of Corbeau Baja Ultra seats. The seats have the 5 harness slots, so with a mounting bar I would/could have belts for track use. I was planning on padding/covering the bar before installing it. The reason for access to the rear of the cabin is for cleaning carpets and glass. Not planning on using the rear seats except for occasional carrying space.
SAIGON 68
DAS went in. took 20 minutes. that's quality engineering. jmho, jp
I have the auto power in my 72, no rear seats, I'm 6-4 and it's a ***** getting back there, but doable to clean the rear glass.
72 911 Although it is done at the moment, it will never be finished. |
Administrator
Pad the bar wherever it comes within 18" of your head. Use the high-density SFI padding.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
sent you an e mail
db
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
