perry11
911 want start
turn key want start . changed dme relay, also checked fuses, and changed fuel filter been sitting for 2 months. also jump fuse to fuse fuel pump works. 1984 carrera.battery seems good. want make cranking sound.
Old 02-24-2011, 06:55 PM
schumicat's Avatar
you need to explain what happens when key turned. nothing? cranks slowly or normally? clicking only? "won't start" can mean lots of things.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 02-24-2011, 07:52 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Welcome aboard Perry!
So I take it your starter will not turn over?
Take a long wooden shaft and have a helper turn the key ( make sure it is not in gear )
Get under and in front of passenger rear wheel, tap the Solenoid while trying to turn the key. While sitting it may have frozen a bit, was it moist where you had it stored for so long.
Also How do you know battery is good? Did you measure at rest and when you turned the key? Try jumper cables and ask your helper to rev their engine to 2000 RPMs then try starting her.
Break a Leg!
Jim
You can always push start her, but test the battery to make certain she will stay on. Sitting 2 months will drain the battery more than you think especially if you have not disconnected it. 3% per day in loss.
'85 Carrera Targa
PCA/POC
Old 02-24-2011, 08:50 PM
