Born to Lose, Live to Win
speedometer repair place to recommend
Thought I would mention...besides the usual speedo/odometer repair places...I used Southern Electronics in Virginia to repair my odometer and calibrate the speedo. Highly recommended. They had it in their possession, just less than 24 hours. with regular UPS land from NY, I had it back in 7 days. They gave it a 27 mile test before returning and did a fine job!
http://www.navhq.com/
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
What did they charge you? My speedo is off about 5mph at 60mph. I just took out my speedo because I heard some noise in their at 60mph when I gave it some gas. My odometer isnt working so I thought it was the gears making some noise. But the gears look good! Im starting to think its the speedo cable that isnt working but the speedometer works.
Any ideas out there? Its a 74 Targa.
'74 Metallic Salmon 2.7L more like 3.0L after rebuild. All Updates! |
it was about $195..but that is to replace the gear AND calibrate. I have no idea what they might charge you. I have an electronic VDO
I changed my cable first (bouncy needle) but the bouncing continued, hence the repair. Happy with the service.
'72 911T gone '85 TVR |
Sent mine to North Hollywood Speedometer, repaired it perfect.
SPEEDO REPAIR...
Howdy,
I recently had my "84" 911 clock repaired at Palo Alto Speedometer Service in Palo Alto, CA. Helmut Mees (sp) is second generation, I did business with his father in the 80's. They're a VDO Factory Authorized Repair station. They charged me $135.00 with shipping for my clock repair. It was beautifully done. They were responsive to my e-mails and had good follow through. http://www.paspeedo.com/porsche.htm
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
How do you look for someone local to do this? I want to just TEST my speedo to see if it's working or if I have an issue with the wiring. I'm in Dallas...what sort of search will I do? I'm thinking there's no point in sending it all the way to Palo Alto or North Hollywood just to find out it works fine.
THanks
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
if you are considering sending to Palo Alto, I suggest doing a few searches
North Hollywood Speedo.......talk about quality and service!!!!
Neil
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Thanks, I was hoping to get suggestions for looking for a local Dallas company but maybe I should just go ahead and send it to NHS.
Speedometer & Odometer Repairs — Overseas Speedometer
These guys are in Austin,Tx They just did my speedo/odometer....great job, quick turn around...$150.00, I think? |
another plug for NHWS - cheap, quick and perfect....
oh..... and EASY !! |
I had my speedo done at NHWS and my tach done at P.A., both did great work.
72 911 Although it is done at the moment, it will never be finished. |
MBruns for President
North Hollywood for me too - they even made my gauges look older than they actually were - more along the early cars and the 356's
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
