Mike80911's Avatar
Wind Noise
OK so I test drove an 87 930 Coupe today and there was alot of wind noise coming in I could not pin down if it was coming from the sunroof or the windshield. Is there a common problem with either of those that would cause there to be a lot of wind noise? It was not the windows so those are my only other choices
Old 03-22-2011, 03:51 PM
Northern Motorhead
wildcat077's Avatar
Yep...
I have an 89 coupe and i have a whistling/wind noise coming in at approx 110 KMS per hour and it drove me crazy for a whole summer until i finally tracked it down.
I ended up taping all around the rubber windshield seal with black masking tape,still had the wind noise,then i sealed the sunroof seal and finally narrowed it down to the joints on the sunroof seal.After i completely sealed the sunroof the noise went away so i ordered a new s seal kit from Pelican and it's on my "near future" to do project list !
I would try the sunroof seal first as it was pretty obvious with my car ...
Cheers !
Phil
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-22-2011, 04:29 PM
Mike80911's Avatar
Thanks Phil I was thinking of tracking it down the same was but I have not bought the car yet so I wanted to get some advise first I would think it is not real serious and I am seriously considering buying it but do not want to have trouble finding and fixing it
Old 03-22-2011, 04:37 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Not sure if coupe is the same but my side front quarter window seal on the windshield moved up and had a gap enough for wind to whistle through.
Taping method is a great way to eliminate the source of the culprit.
'85 Carrera Targa
PCA/POC
Old 03-22-2011, 04:38 PM
Northern Motorhead
wildcat077's Avatar
Mike,
I'm sorry,i meant black electrical tape !
It stretches and seals a whole lot better than masking tape ... my bad ... lol
Good luck with your car hunt
Cheers !
Phil
Cheers
Phil
Old 03-22-2011, 05:43 PM
Mitch Leland's Avatar
If you have an old W/S gasket that is dried out from the sun, or if you have an after market W/S gasket you'll get a wind noise under the lower lip of the gasket at the cowl. The factory gasket has a wider lip that seals better, particularly in the corners.
When I changed my old gasket it really helped, then I changed the after market gasket to a factory gasket and it improved that much again...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-22-2011, 09:39 PM
Keep it under 140 mph and you will be fine.
Old 03-23-2011, 02:17 AM
Always learning
Somewhat relevant.... Wurth sell a air leak detection powder. Quite handy for full restos. R
Old 03-23-2011, 03:25 AM
Mike80911's Avatar
Thanks for all of the advise guys and Kach if I wanted to stay under 140 why would I be looking at Turbos :-}
Old 03-23-2011, 07:25 AM
