gordemann's Avatar
stereo whine???
Hello All
I am getting a bad whine from my stereo(in my 1983 911SC) when the key is in the on position..It does make noise when thw engine is running but not as bad..I am puzzled why it is making this noise when the car is not even running.Any suggestions.
Thankx
Old 02-26-2011, 03:16 PM
Old 02-26-2011, 03:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I think electronics shops sell a filter that reduces or eliminates the feed back noise from the coil/plug wires. Some manufacturers state it will not insulate the feedback to stereos.
I remember I had to add that to my VW back in the day
'85 Carrera Targa
PCA/POC
Old 02-26-2011, 03:42 PM
gordemann's Avatar
I have two types of filters and niether seemed to make any difference..
Old 02-26-2011, 03:44 PM
I was going to suggest OT for this topic. At first, I thought you were referring to Mormon wives who berate their husband.
Sherwood
Old 02-26-2011, 04:04 PM
I would say you have interference from an electronic signal. Try separating the audio and power cables, and find a better ground for the head unit.
Old 02-26-2011, 04:05 PM
AutoBahned
RWebb's Avatar
I'd bet it is the CD box.
Old 02-26-2011, 04:15 PM
DRACO A5OG's Avatar
Sherwood
Hey I resent that statement, my wives don't whine much
'85 Carrera Targa
PCA/POC
Old 02-26-2011, 04:24 PM
nineball's Avatar
check the ground for your radio. does the pitch change with the tach? as you accelerate does it get higher?
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 02-26-2011, 04:30 PM
jetstar911's Avatar
Whats your stereo consist of? Just a headunit? Any amplifiers hooked up to the system? Could be anything from a bad ground, pinched RCA cable or speaker line. If you havent changed anything in the install, it could be a bad tracer in a component of even something as small as a bad switch, relay or car ground on the factory side. Unfortunatly its trial and error. Check all grounds, then move to unpluging the RCA cables one by one while the stereo is playing(car running or not). From there disconnect each speaker wire one by one and re connect in the same order while listening to the system to see if the "whine" changes. Finally you may have to pull each component and "bench" each one alone. I know it can be confusing but i hope it helps.
Kane
Old 02-26-2011, 09:26 PM
+1.... And the antenna......
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 02-26-2011, 11:04 PM
